Issues with Nginx Proxy Manager and Nextcloud AiO
    • 30.0.5
    • Unraid 7
    • Nginx Proxy Manager 2.12.2
    • Upon installation and use with Nginx Proxy Manager
    • AiO
    • Not when accessing via NPM
Im having a lot of issues setting up Nextcloud AiO on unraid behind nginx proxy manager. I was unable to get past the 502 error, so I ended up using a cloudflare tunnel instead. The problem is, I still need to use NPM locally as for whatever reason, the nextcloud front end cannot be reached via IP address.
Currently, when visiting my nextcloud url locally, my local DNS route the URL to Nginx which, in theory, routes the traffic to NC. However, I can only get that to work in Nginx using the hostname, using IP gets me a 502 error.
Using the hostname in Nginx works, however I am left with a slew of errors that only appear when accessing NC locally. I’ve tried to decipher these and research resolutions, but fixing these errors is getting incredibly confusing, if anyone could assist that would be awesome
https://pastebin.com/WrjetkXe
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "overwritehost": "drive.jpfeifer.cloud",
        "overwriteprotocol": "https",
        "redis": {
            "port": 6379
            "localhost",
            "192.168.0.11"
        "dbtype": "pgsql",
        "version": "30.0.5.1",
        "overwrite.cli.url": "https:\/\/drive.jpfeifer.cloud\/",
        "dbport": "",
        "loglevel": 2,
        "log_type": "file",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "default_phone_region": "US",
        "mail_sendmailmode": "smtp",
        "mail_smtpsecure": "ssl",
        "mail_smtpport": "465",
        "mail_smtpauth": 1,
        "DOMAIN": "drive.jpfeifer.cloud"
  • activity: 3.0.0
  • admin_audit: 1.20.0
  • bruteforcesettings: 3.0.0
  • calendar: 5.0.9
  • circles: 30.0.0
  • cloud_federation_api: 1.13.0
  • comments: 1.20.1
  • contacts: 6.1.3
  • contactsinteraction: 1.11.0
  • dashboard: 7.10.0
  • dav: 1.31.1
  • deck: 1.14.3
  • federatedfilesharing: 1.20.0
  • federation: 1.20.0
  • files: 2.2.0
  • files_antivirus: 5.6.1
  • files_downloadlimit: 3.0.0
  • files_pdfviewer: 3.0.0
  • files_reminders: 1.3.0
  • files_sharing: 1.22.0
  • files_trashbin: 1.20.1
  • files_versions: 1.23.0
  • firstrunwizard: 3.0.0
  • forms: 4.3.5
  • logreader: 3.0.0
  • lookup_server_connector: 1.18.0
  • nextcloud-aio: 0.7.0
  • nextcloud_announcements: 2.0.0
  • notes: 4.11.0
  • notifications: 3.0.0
  • notify_push: 1.0.0
  • oauth2: 1.18.1
  • password_policy: 2.0.0
  • photos: 3.0.2
  • privacy: 2.0.0
  • provisioning_api: 1.20.0
  • recommendations: 3.0.0
  • related_resources: 1.5.0
  • richdocuments: 8.5.3
  • serverinfo: 2.0.0
  • settings: 1.13.0
  • sharebymail: 1.20.0
  • sip_trip_phone: 1.1.7
  • spreed: 20.1.3
  • support: 2.0.0
  • survey_client: 2.0.0
  • systemtags: 1.20.0
  • tasks: 0.16.1
  • text: 4.1.0
  • theming: 2.5.0
  • twofactor_backupcodes: 1.19.0
  • twofactor_totp: 12.0.0-dev
  • user_migration: 7.0.1
  • user_status: 1.10.0
  • viewer: 3.0.0
  • weather_status: 1.10.0
  • webhook_listeners: 1.1.0-dev
  • workflowengine: 2.12.0
  • app_api: 4.0.5 (installed 4.0.5)
  • encryption: 2.18.0
  • files_external: 1.22.0
  • suspicious_login: 8.0.0
  • twofactor_nextcloud_notification: 4.0.0
  • user_ldap: 1.21.0
you can check my topic about Nextcloud AIO + Nginx Proxy server setting (as selfhosted solution).
You can find there:
  • my docker-compose.yml file
  • screenshots how to set up subdomain/domain in NGINX Proxy server
Feel free to contact me for other details.
Unfortunately those settings do not work for me. It should be noted that, for whatever reason, using the IP in NPM doesnt work, I have to use the container name, even though the container port is mapped to the server port.
I also tried to add the the APACHE_IP_BINDING= ‘0.0.0.0’ to the config, and i still cannot reach it via IP (I can reach the master container by IP just fine). I dont know if maybe this cannot be updated from the docker config after already set up or what, but i aslo tried removing the apache container and letting the master container rebuild it with no luck.
My docker settings
Have you ever seen something like this where NPM flat out refuses to connect to the IP given for nextcloud?
This appears to have been an issue with the way NPM was networking with unraid and has been resolved.
