Can’t access to my nextcloud after upgrade of system. but i try to do a fresh install the new system and i can’t install the nextcloud.
Nextcloud version 13.0.2:
Operating system and version Fedora 28:
Apache or nginx version Apache 2.4.33:
PHP version 7.2.5-1:
i had that nextcloud version on Fedora 27. The last weekend i updated the system to Fedora 28 using dnf.
When i go to test my nextcloud it showme an error. Ok, we try too many things, like reinstall, remove, downgrade packages, but nothing resolve my issue.
I remember when update the system nextcloud was on maintenance mode.
If i try to do something with the CLI (occ) it show me too many errors too.
Well, i do 2 fresh installs on Fedora 28, with php, apache and mariadb. And i download the nextcloud 13.0.2 version and try to install, but i can’t. Show me “internal server error” too.
What are i doing bad? some bug with any of this versions? or system? This configuration files works on Fedora 27 perfectly.
Please, some help and thanks.
Is this the first time you’ve seen this error? Y:
- Access to my domain of nextcloud
- See the error
- Error: "Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the webserver log."
I can't access to that site. But nextcloud.log don't show me anything.
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => 'domain.ovh',
'datadirectory' => '/path/data',
'overwrite.cli.url' => 'https://domain/',
'version' => '13.0.2.1',
'dbname' => 'nubemagna',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
'updater.release.channel' => 'beta',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'logfile' => '/path/nextcloud.log',
'theme' => '',
'loglevel' => 2,
'mail_from_address' => 'postmaster',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'domain.ovh',
'mail_smtpauth' => 1,
'mail_smtphost' => 'ssl0.ovh.net',
'mail_smtpport' => '465',
'mail_smtpsecure' => 'ssl',
'mail_smtpname' => 'postmaster@domain.ovh',
'mail_smtppassword' => '',
Thanks and regards.
