Hello everyone,
I recently installed Collabora on my Nextcloud server and I’ve encountered some issues that I can’t seem to resolve. Collabora is showing a strange IP address and doesn’t seem to be working properly. Here are some details:
Nextcloud Version:27.0.1
Ubuntu, PHP Version: 8.2.8
Collabora CODE (x86) Version:23.5.104
Nextcloud Office: 8.1.0
Problem Description:
Collabora is not functioning, and I continually receive an error message in the logs. Interestingly, the IP address reported in the error log belongs to an intranet the server was connected to two years ago. I am puzzled as to why Collabora is attempting to connect to it.
I’ve attached below the error log that I received at the end.
Steps Taken So Far:
I’ve attempted to resolve the issue by doing the following:
- Reinstalled Collabora and Nextcloud office.
- Fixed all other Nextcloud configuration errors in the system.
- Checked the network connection between my Nextcloud and Collabora servers.
- Checked the Collabora server URL in the Nextcloud settings.
Unfortunately, none of these steps have resolved the issue.
I would really appreciate any help or suggestions on how to fix this. Thanks in advance!
[richdocuments] Fehler: GuzzleHttp\Exception\ConnectException: cURL error 7: Failed to connect to 192.168.188.58 port 80: Network is unreachable (see libcurl - Error Codes) for http://192.168.188.58/apps/richdocumentscode/proxy.php?req=/hosting/capabilities at <>
- /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 158
GuzzleHttp\Handler\CurlFactory::createRejection(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 110
GuzzleHttp\Handler\CurlFactory::finishError() - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php line 47
GuzzleHttp\Handler\CurlFactory::finish() - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 137
GuzzleHttp\Handler\CurlHandler->__invoke() - /var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php line 114
GuzzleHttp\Middleware::GuzzleHttp{closure}(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php line 35
OC\Http\Client\DnsPinMiddleware->OC\Http\Client{closure}(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 31
GuzzleHttp\PrepareBodyMiddleware->__invoke() - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php line 71
GuzzleHttp\Middleware::GuzzleHttp{closure}(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 63
GuzzleHttp\RedirectMiddleware->__invoke() - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php line 75
GuzzleHttp\Middleware::GuzzleHttp{closure}(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php line 331
GuzzleHttp\HandlerStack->__invoke() - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php line 168
GuzzleHttp\Client->transfer() - /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php line 187
GuzzleHttp\Client->requestAsync(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/lib/private/Http/Client/Client.php line 226
GuzzleHttp\Client->request() - /var/www/nextcloud/apps/richdocuments/lib/Service/CapabilitiesService.php line 135
OC\Http\Client\Client->get() - /var/www/nextcloud/apps/richdocuments/lib/Service/CapabilitiesService.php line 73
OCA\Richdocuments\Service\CapabilitiesService->refetch() - /var/www/nextcloud/apps/richdocuments/lib/AppInfo/Application.php line 85
OCA\Richdocuments\Service\CapabilitiesService->getCapabilities() - /var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php line 45
OCA\Richdocuments\AppInfo\Application->OCA\Richdocuments\AppInfo{closure}(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php line 50
OC\AppFramework\Bootstrap\FunctionInjector->injectFn() - /var/www/nextcloud/apps/richdocuments/lib/AppInfo/Application.php line 84
OC\AppFramework\Bootstrap\BootContext->injectFn() - /var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php line 200
OCA\Richdocuments\AppInfo\Application->boot() - /var/www/nextcloud/lib/private/App/AppManager.php line 437
OC\AppFramework\Bootstrap\Coordinator->bootApp() - /var/www/nextcloud/lib/private/App/AppManager.php line 216
OC\App\AppManager->loadApp() - /var/www/nextcloud/lib/private/legacy/OC_App.php line 126
OC\App\AppManager->loadApps() - /var/www/nextcloud/lib/base.php line 1051
OC_App::loadApps() - /var/www/nextcloud/index.php line 36
OC::handleRequest()
GET /index.php/apps/logreader/poll?lastReqId=8O2XXe5z1R5pHtrSZ0hy
from 192.168.178.52 by soren at 2023-07-24T00:00:01+00:00
