Issues Nextcloud 15.0.4 with LDAP Secure
Hello ,
I am trying to configure ldap secure to connect to our AD 2K12 server
All connectivity are tested and working testldaps
When i am trying to connect Plain ldap its works as shown below image , but when i try ldaps ,cant get it work in any way , looking on the logs , i can see error reltaed to ldap , but i cant understand how its reltaed to the configuration secure ldap,
Please advice
Thanks
ldaps not working
NC logs
I’d give you the same advice as this (check the Login Attributes tab):
sorry not working following below is my setting with ldaps
when doing test i get following
when doing plain ldap only removing ldaps:// and changing port to 389 , works
Please HELP
Can you connect to any other LDAPS servers?
i have other ldap servers, i have the same issue ,BTW if i use LDAP admin i connect without any issue to either secure or TLS
You can connect to other LDAPS servers using ‘LDAP admin’ on the same host as Nextcloud?
