### How to use GitHub
* Please use the š [reaction](https://blog.github.com/201ā¦6-03-10-add-reactions-to-pull-requests-issues-and-comments/) to show that you are affected by the same issue.
* Please don't comment if you have no relevant information to add. It's just extra noise for everyone subscribed to this issue.
* Subscribe to receive notifications on status change and new comments.
**Describe the bug**
The "Settings" button uses the wrong UI and the icon inside the button is not positioned properly.
**To Reproduce**
Steps to reproduce the behavior:
1. Open "Deck"
2. See the settings button using the wrong UI
**Expected behavior**
The settings button uses the same UI as other apps like Files or Contacts.
**Screenshots**
Settings button of "Deck" - you can see it is in the form of a "pill", wrong icon and the icon is not positioned properly:
<img width="740" height="204" alt="Image" src="https://github.com/user-attachments/assets/e46d2aaa-f8fa-43dc-bbcb-bebda96c741d" />
Settings button of "Files" - correct "button" shape and icon positioned in the right way:
<img width="624" height="179" alt="Image" src="https://github.com/user-attachments/assets/28dd11a8-afff-4f3e-bedc-d729d677c36d" />
Settings button of "Contacts" - correct "button" shape and icon positioned in the right way:
<img width="680" height="212" alt="Image" src="https://github.com/user-attachments/assets/1e560037-124e-4116-b6be-2443227fce65" />
**Client details:**
- OS: Windows 11
- Browser - not relevant, happens in all browsers (Firefox, Chrome, Edge, Vivaldi, Safari)
**Operating system**: Ubuntu 24.04
**Web server:** Apache
**Database:** MariaDB
**PHP version:** PHP 8.4
**Nextcloud version:** 32.0.1
**Where did you install Nextcloud from:**
**Signing status:**
No errors have been found.
**List of activated apps:**
- activity: 5.0.0-dev.0
- admin_audit: 1.22.0
- app_api: 32.0.0
- bookmarks: 16.0.0
- calendar: 6.0.2
- circles: 32.0.0
- collectives: 3.2.4
- comments: 1.22.0
- contacts: 8.0.5
- contactsinteraction: 1.13.1
- dav: 1.34.2
- deck: 1.16.0
- drawio: 3.1.2
- external: 7.0.0
- federation: 1.22.0
- files: 2.4.0
- files_reminders: 1.5.0
- files_sharing: 1.24.0
- files_trashbin: 1.22.0
- files_versions: 1.25.0
- firstrunwizard: 5.0.0-dev.0
- flow_notifications: 3.0.0
- impersonate: 3.0.0
- logreader: 5.0.0-dev.0
- memories: 7.7.0
- notes: 4.12.3
- notifications: 5.0.0-dev.0
- oauth2: 1.20.0
- photos: 5.0.0-dev.1
- previewgenerator: 5.10.0
- privacy: 4.0.0-dev.0
- profile: 1.1.0
- provisioning_api: 1.22.0
- richdocuments: 9.0.1
- serverinfo: 4.0.0-dev.0
- settings: 1.15.1
- sharebymail: 1.22.0
- spreed: 22.0.2
- support: 4.0.0-dev.0
- survey_client: 4.0.0-dev.0
- systemtags: 1.22.0
- text: 6.0.1
- theming: 2.7.0
- theming_customcss: 1.19.0
- twofactor_webauthn: 2.4.1
- updatenotification: 1.22.0
- viewer: 5.0.0-dev.0
- webhook_listeners: 1.3.0
- whiteboard: 1.4.0
- workflowengine: 2.14.0
- dashboard: 7.12.0 (installed 7.8.0)
- dicomviewer: 2.3.1 (installed 2.3.1)
- encryption: 2.20.0 (installed 2.13.0)
- files_external: 1.24.0 (installed 1.19.0)
- recommendations: 5.0.0-dev.0 (installed 0.4.0)
- related_resources: 3.0.0-dev.0 (installed 1.1.0-alpha1)
- twofactor_totp: 14.0.0
- user_ldap: 1.23.0
- user_status: 1.12.0 (installed 1.5.0)
- weather_status: 1.12.0 (installed 1.3.0)
**Nextcloud configuration:**
"***REMOVED SENSITIVE VALUE***"
"skeletondirectory": "",
"overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
"dbtype": "mysql",
"version": "32.0.1.2",
"htaccess.RewriteBase": "\/",
"dbpersistent": true,
"filelocking.enabled": true,
"redis": {
"port": 0,
"dbindex": 0
"knowledgebaseenabled": false,
"theme": "",
"loglevel": 2,
"log_authfailip": true,
"mysql.utf8mb4": true,
"mail_smtpmode": "sendmail",
"mail_smtpsecure": "ssl",
"versions_retention_obligation": "auto, 180",
"has_rebuilt_cache": true,
"default_language": "de",
"default_phone_region": "DE",
"log_rotate_size": 52428800,
"profile.enabled": false,
"preview_max_x": 1920,
"preview_max_y": 1920,
"mail_sendmailmode": "smtp",
"mail_smtpauth": true,
"mail_smtpport": "465",
"reference_opengraph": true,
"integrity.check.disabled": false,
"defaultapp": "files",
"maintenance_window_start": 2,
"apps_paths": [
"path": "\/var\/www\/nextcloud\/apps",
"url": "\/apps",
"writable": true
"app_install_overwrite": [],
"forbidden_filename_basenames": [
"con",
"prn",
"aux",
"nul",
"com0",
"com1",
"com2",
"com3",
"com4",
"com5",
"com6",
"com7",
"com8",
"com9",
"com\u00b9",
"com\u00b2",
"com\u00b3",
"lpt0",
"lpt1",
"lpt2",
"lpt3",
"lpt4",
"lpt5",
"lpt6",
"lpt7",
"lpt8",
"lpt9",
"lpt\u00b9",
"lpt\u00b2",
"lpt\u00b3"
"forbidden_filename_characters": [
"forbidden_filename_extensions": [
".filepart",
".part"
"memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
"memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
"memories.index.path.blacklist": "***REMOVED SENSITIVE VALUE***",
"enabledPreviewProviders": [
"OC\\Preview\\PNG",
"OC\\Preview\\JPEG",
"OC\\Preview\\GIF",
"OC\\Preview\\HEIC",
"OC\\Preview\\BMP",
"OC\\Preview\\XBitmap",
"OC\\Preview\\MP3",
"OC\\Preview\\TXT",
"OC\\Preview\\MarkDown",
"OC\\Preview\\Movie",
"OC\\Preview\\MKV",
"OC\\Preview\\MP4",
"OC\\Preview\\AVI",
"OC\\Preivew\\PDF",
"OC\\Preview\\Imaginary"
"memories.gis_type": 1,
"enable_previews": true,
"preview_imaginary_url": "***REMOVED SENSITIVE VALUE***"
**Are you using an external user-backend, if yes which one:** no
</details>
