example
longer
example
here
Operating system and version (eg, Ubuntu 20.04): Debain 10
The startup is stuck at 70-aliases
Yes
- Install Rancher with docker
- Deploy nextcloud linuxserver/nextcloud image
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 01-envfile: executing...
[cont-init.d] 01-envfile: exited 0.
[cont-init.d] 10-adduser: executing...
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User uid: 1000
User gid: 1000
[cont-init.d] 10-adduser: exited 0.
[cont-init.d] 20-config: executing...
[cont-init.d] 20-config: exited 0.
[cont-init.d] 30-keygen: executing...
using keys found in /config/keys
[cont-init.d] 30-keygen: exited 0.
[cont-init.d] 40-config: executing...
[cont-init.d] 40-config: exited 0.
[cont-init.d] 50-install: executing...
[cont-init.d] 50-install: exited 0.
[cont-init.d] 60-memcache: executing...
[cont-init.d] 60-memcache: exited 0.
[cont-init.d] 70-aliases: executing...
