Issues after uprading to 25.0.1
Hi there,
after upgrading to 25.0.1 on my NC instance running on TrueNas (FreeBSD 13), I get some weird problems:
Klicking for example in Admin->Overview leads to an internal error
Watching the logfile (occ log:watch) shows, NC has problems with LocalAddressChecker.php
Error index Exception: strpos() expects parameter 1 to be string, bool 2022-11-04T14:04:41+00:00
given in file
‘/usr/local/www/nextcloud/lib/private/Http/Client/LocalAddressChecker.php’
                          line 82 at lib/private/AppFramework/Http/Dispatcher.php line
                          165
                          0. .../App.php line 172
                             OC\AppFramework\Http\Dispatcher->dispatch(
                          1. .../Route/Router.php line 298
                             OC\AppFramework\App::main(
                          2. lib/base.php line 1047
                             OC\Route\Router->match(
                          3. index.php line 36
                             OC::handleRequest(
                          Caused by TypeError: strpos() expects parameter 1 to be string, bool
                          given at lib/private/Http/Client/LocalAddressChecker.php line
                          82
                           0. .../Http/Client/LocalAddressChecker.php line 82
                              strpos(
                           1. .../Client.php line 184
                              OC\Http\Client\LocalAddressChecker->ThrowIfLocalAddress(
                           2. .../Client.php line 217
                              OC\Http\Client\Client->preventLocalAddress(
                           3. .../VersionCheck.php line 131
                              OC\Http\Client\Client->get(
                           4. .../VersionCheck.php line 92
                              OC\Updater\VersionCheck->getUrlContent(
                           5. .../UpdateChecker.php line 52
                              OC\Updater\VersionCheck->check(
                           6. .../Admin.php line 95
                              OCA\UpdateNotification\UpdateChecker->getUpdateState(
                           7. .../CommonSettingsTrait.php line 129
                              OCA\UpdateNotification\Settings\Admin->getForm(
                           8. .../AdminSettingsController.php line 83
                              OCA\Settings\Controller\AdminSettingsController->formatSettings(
                           9. .../CommonSettingsTrait.php line 149
                              OCA\Settings\Controller\AdminSettingsController->getSettings(
                          10. .../AdminSettingsController.php line 68
                              OCA\Settings\Controller\AdminSettingsController->getIndexResponse(
                          11. .../Dispatcher.php line 225
                              OCA\Settings\Controller\AdminSettingsController->index(
                          12. .../Dispatcher.php line 133
                              OC\AppFramework\Http\Dispatcher->executeController(
                          13. .../App.php line 172
                          14. .../Route/Router.php line 298
                          15. lib/base.php line 1047
                          16. index.php line 36
                              OC::handleRequest(
In file lib/private/Http/Client/LocalAddressChecker.php I found, that $host = idn_to_utf8(strtolower(urldecode($host))); returns false and not a string.
Any idea whats wrong here?
Regards and kudos for the great release
Markus
I found a solution bymyself.
I downloaded a fresh source zip (latest.zip) and switched my installation to this fresh set of files.
No more errors from now.
I do not understand why this helped but it did so far.
Thanks for reading
Markus
Did you use the updater app in the first place? And then just using the code of the zip-archive solved the issue?
I had the same issue updateing to 24.0.9, not sure if they are linked. I’m also running on a FreeBSD system (version 12). On 24.0.7 I didn’t have the problem.
I’m running a test setup on the same server with NC 25.0.4RC1.
I created a bug report
