Hello
Can someone pls help me with this problem? I’m running nexcloud plugin in TrueNAS. I’m trying to update the system but I keep getting error on file called * .htaccess.dist. dont know where to find it and delete it. can someone pls tell me to find the directory of this file in TrueNAS or solve this problem?
It is probably in the main nextcloud folder where the code is. locate and other tools on Linux can help as well.
Because it is a dot-file (starts with a dot) the file is in some file managers hidden. Perhaps you can use another file manager or use direct shell access.
was there a solution for this? i still have the same error. can someone help?
