Issue with Moving Recurring Events Between Calendars
I’ve encountered an unusual behavior while working with recurring events in your calendar:
I have created several recurring events.
When I try to move them to another calendar, I can only transfer the first event in the series. The subsequent, inherited events cannot be moved.
After analyzing the situation, I concluded that transferring is restricted for the child events. I would like to clarify:
Is this an intended feature of your calendar?
If it is a bug, are there any solutions to address this issue?
Thank you in advance for your assistance!
There is a report on github:
You can share your ideas, if you want to show your support, you can give the initial post a thumbs up.
