Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): Newest
Operating system and version (eg, Ubuntu 20.04): Docker AIO
Apache or nginx version (eg, Apache 2.4.25): Docker AIO
PHP version (eg, 7.4): Docker AIO
Sending mails not working:
A problem occurred while sending the email. Please revise your settings. (Error: Email could not be sent. Check your mail server log)
‘mail_from_address’ => ‘admin’,
‘mail_sendmailmode’ => ‘smtp’,
‘mail_domain’ => ‘XXX.ovh’,
‘mail_smtpauth’ => 1,
‘mail_smtpauthtype’ => ‘LOGIN’,
‘mail_smtphost’ => ‘XXXt’,
‘mail_smtpport’ => ‘465’,
‘mail_smtpname’ => ‘admin@XXX.ovh’,
‘mail_smtppassword’ => ‘Password’,
‘mail_smtpsecure’ => ‘ssl’,
` 3 seconds","userAgent":"--","version":"27.1.3.2","data":{"app":"cron"}}
{"reqId":"uMSE13ud2YSZkbqdBA3s","level":0,"time":"2023-11-11T16:24:40+00:00","remoteAddr":"195.60.216.10","user":"admin","app":"no app in context","method":"POST","url":"/settings/admin/mailtest","message":"Email transport \"Symfony\\Component\\Mailer\\Transport\\Smtp\\SmtpTransport\" starting","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36","version":"27.1.3.2","data":[]}
{"reqId":"uMSE13ud2YSZkbqdBA3s","level":0,"time":"2023-11-11T16:24:50+00:00","remoteAddr":"195.60.216.10","user":"admin","app":"core","method":"POST","url":"/settings/admin/mailtest","message":"Sending mail to \"Array\n(\n [XXXX@gmail.com] => admin\n)\n\" with subject \"Email setting test\" failed","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36","version":"27.1.3.2","exception":{"Exception":"Symfony\\Component\\Mailer\\Exception\\TransportException","Message":"Connection could not be established with host \"ssl://mail47.mydevil.net:465\": stream_socket_client(): Unable to connect to ssl://mail47.mydevil.net:465 (Operation timed out)","Code":0,"Trace":[{"function":"Symfony\\Component\\Mailer\\Transport\\Smtp\\Stream\\{closure}","class":"Symfony\\Component\\Mailer\\Transport\\Smtp\\Stream\\SocketStream","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/symfony/mailer/Transport/Smtp/Stream/SocketStream.php","line":157,"function":"stream_socket_client","args":["ssl://mail47.mydevil.net:465",0,"",10,4,null]},{"file":"/var/www/html/3rdparty/symfony/mailer/Transport/Smtp/SmtpTransport.php","line":251,"function":"initialize","class":"Symfony\\Component\\Mailer\\Transport\\Smtp\\Stream\\SocketStream","type":"->","args":[]},{"file":"/var/www/html/3rdparty/symfony/mailer/Transport/Smtp/SmtpTransport.php","line":194,"function":"start","class":"Symfony\\Component\\Mailer\\Transport\\Smtp\\SmtpTransport","type":"->","args":[]},{"file":"/var/www/html/3rdparty/symfony/mailer/Transport/AbstractTransport.php","line":72,"function":"doSend","class":"Symfony\\Component\\Mailer\\Transport\\Smtp\\SmtpTransport","type":"->","args":[["Symfony\\Component\\Mailer\\SentMessage"]]},{"file":"/var/www/html/3rdparty/symfony/mailer/Transport/Smtp/SmtpTransport.php","line":136,"function":"send","class":"Symfony\\Component\\Mailer\\Transport\\AbstractTransport","type":"->","args":[["Symfony\\Component\\Mailer\\SentMessage"],["Symfony\\Component\\Mailer\\DelayedEnvelope"]]},{"file":"/var/www/html/3rdparty/symfony/mailer/Mailer.php","line":45,"function":"send","class":"Symfony\\Component\\Mailer\\Transport\\Smtp\\SmtpTransport","type":"->","args":[["Symfony\\Component\\Mime\\Email"],null]},{"file":"/var/www/html/lib/private/Mail/Mailer.php","line":216,"function":"send","class":"Symfony\\Component\\Mailer\\Mailer","type":"->","args":[["Symfony\\Component\\Mime\\Email"]]},{"file":"/var/www/html/apps/settings/lib/Controller/MailSettingsController.php","line":168,"function":"send","class":"OC\\Mail\\Mailer","type":"->","args":[["OC\\Mail\\Message"]]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"sendTestMail","class":"OCA\\Settings\\Controller\\MailSettingsController","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Settings\\Controller\\MailSettingsController"],"sendTestMail"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":183,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Settings\\Controller\\MailSettingsController"],"sendTestMail"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\MailSettingsController","sendTestMail",["OC\\AppFramework\\DependencyInjection\\DIContainer"],["settings.MailSettings.sendTestMail"]]},{"file":"/var/www/html/lib/base.php","line":1068,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/admin/mailtest"]},{"file":"/var/www/html/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/3rdparty/symfony/mailer/Transport/Smtp/Stream/SocketStream.php","Line":154,"message":"Sending mail to \"Array\n(\n [maciejpawlaczyk3@gmail.com] => admin\n)\n\" with subject \"Email setting test\" failed","exception":{},"CustomMessage":"Sending mail to \"Array\n(\n [XXX@gmail.com] => admin\n)\n\" with subject \"Email setting test\" failed"}}
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
