Issue with code integrity check - invalid hash / core folder
How to solve this?
Some files have not passed the integrity check. Further information on how to resolve this issue can be found in our documentation. (List of invalid files… / Rescan…)
From that I get:
Results
  • core
    • INVALID_HASH
      • .htaccess
      • core/doc/admin/_sources/configuration_files/collaborative_documents_configuration.txt
      • core/doc/admin/_static/img/note_pencil.svg
      • core/doc/admin/_static/img/warning.svg
      • core/doc/admin/_static/style.css
      • core/fonts/LICENSE.txt
      • core/vendor/jsTimezoneDetect/jstz.js
    • FILE_MISSING
      • .user.ini
  • files_external
    • INVALID_HASH
      • 3rdparty/Dropbox/API.php
  • files_texteditor
    • INVALID_HASH
      • js/vendor/ace/src-noconflict/mode-diff.js
Raw output
Array
[core] => Array
[INVALID_HASH] => Array
[.htaccess] => Array
[expected] => ab5f4c44ba2f9c66f2ed25c3ad3d84660b2808cca11ffa8fe2778a648a054d8ada495a0bf4715dc873aac1efe8dfd92a72f9a24441d8f5240834e639325fd892
[current] => cf83e1357eefb8bdf1542850d66d8007d620e4050b5715dc83f4a921d36ce9ce47d0d13c5d85f2b0ff8318d2877eec2f63b931bd47417a81a538327af927da3e
                [core/doc/admin/_sources/configuration_files/collaborative_documents_configuration.txt] => Array
                        [expected] => 54e01aeda1129411b290fe13d00ab5dc22e6035cbfed71bbed565afd306e5b16af8deca018d9057bf6e36a54dbb92a12a8a08a2652a539ea3c7e007571d017d4
                        [current] => d813044e8820af24c6a02b33578a82b01e1db34cb70b75fbc2864e1a1f825556debf8fab61ebdcaae94c7963d1e71ae57410be6dcee598c444559de6e98f5fb8
                [core/doc/admin/_static/img/note_pencil.svg] => Array
                        [expected] => 78b9df57afe9468145e6e375cd1f61274b269b9c3019726a99e043ae952367acf53cf471cbc5b3dcca2e68367c2c4422d4a9f9a9fdbb11f9b962845ac77857de
                        [current] => 97117ce2827cc1b742678b52fc100de1e7d3fdb1adeea04a301c012e7f95b66e10a369c6a83ba89a707c4232b5e31fba3d5e58b0e0d970f22031d0704eebb5a9
                [core/doc/admin/_static/img/warning.svg] => Array
                        [expected] => e8647b47ef1531b8c2fcdd51f76996fe85476467fc694540f3dcf8ce7e7da489e99edae5a158742da71c07dc09ccfaf721f01c1c4bda3f5bae9b711981b71a1b
                        [current] => 85687f19cf204716e9b1c608682aa22c045b6f8284a3496db07f13200952491bfea54deee7ef11115c0dedfd87443c7022ef05792892a8a984866752c8ec5726
                [core/doc/admin/_static/style.css] => Array
                        [expected] => 894b1bea3e2b6bc61824ffebc081339a6caf0b57cda7fa9b9c9a5965e2a165dc177055db176cb535ef465c927b4bc4848802fe3e1b0fb709194b3cb7d2f90f8d
                        [current] => 5d9fbe71f0eae36c5a9c50f98733cc9e7a5bc7b2b56e3937c4431cf5e54649667bbe8f5900cdcbfbaa8b1eb8d5476d42a278d210c38110411885ad818e3a963a
                [core/fonts/LICENSE.txt] => Array
                        [expected] => 4cc5a12bfe984c0a50bf7943e2d70a948d520ef423677c77629707aace3a95aa378d205de929105d644680679e70ef2449479b360ad44896b75bafed66613272
                        [current] => 98f6b79b778f7b0a15415bd750c3a8a097d650511cb4ec8115188e115c47053fe700f578895c097051c9bc3dfb6197c2b13a15de203273e1a3218884f86e90e8
                [core/vendor/jsTimezoneDetect/jstz.js] => Array
                        [expected] => ece74dd6f5fc9587cf167dd17df51b66f70bd711f445da8d1d21bb1b0570f3c97b25d3ece110b08e2f2b294369d9b775cc169b666840a5b769ba338aa6d73d48
                        [current] => beae737d18aae6e8c5fdfb0bf3389b687ec746e6b334185710cc5b8f45b73b3c57442db541807ab440b55517ef2d138f4c40148abafcb6462481016b617e1f53
        [FILE_MISSING] => Array
                [.user.ini] => Array
                        [expected] => 0a557e3cdca4c2e3675deed761d79d109011dcdebbd9c7f6429f1d3476938ec95729543d7384651d1d0c48e26c5024cc5f517445920915a704ea748bdb903c5f
                        [current] =>
[files_external] => Array
                [3rdparty/Dropbox/API.php] => Array
                        [expected] => a6866ef3ceeb26d9d4b2ccc343aeaf626c82f03e279962bc7d761a68e87e5a7916ff0bcf7a350e20889557336ed9c5dd1651cfe513fa04bb8a03cd6d8f9cc484
                        [current] => 917eed2c4f6359a4d0b8658a36404c83344b0bf72ccda614dd59f97d099b3d9ef4e86691401c64d3754c3f7e0fa163eab946a25dbc7bc65e1694ffd47a054317
[files_texteditor] => Array
                [js/vendor/ace/src-noconflict/mode-diff.js] => Array
                        [expected] => 4a59b6376376b81e4e12ccc345065db62029a61035a88e19b1be3d7ec4cd9f86444121cca6d46c44a5f86e4f5b44d5109cbc77e80c07ff8dbce61f758b88e765
                        [current] => 298cba4d3b472b418aca47db6522c752a4b5530de3f6f2d83eb42eb5fe4231356bfd860a7e2f735b3e5ced759dbc6ca26fc6a18c49bd7ffa07d5a6faa78ae51d
you can get the original files of your Nextcloud here: nextcloud.com/changelog
The hidden .htaccess-file is often omitted when copying files. The others were perhaps skipped by accident or modified during file transfer (especially via FTP).
I referenced this solution here:
please add to the docs because there is NO hint on where to get the correct files
in my case the updater was just maybe skipping files? so i reported a bug, but i cannot reproduce it and noone can
I replaced the files from the 24.0.6 zip
the Nextcloud Manual pdf error is gone
the pdf worker js map is still there
i reported a bug, and you closed it, because you feel insulted by commuity users…
for what reason do you actually do opensource if you try to force payment to people who work for free for you?
wanna be like Google?
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
  • files_pdfviewer
    • INVALID_HASH
      • js/pdfjs/build/pdf.worker.js.map
Raw output
Array
[files_pdfviewer] => Array
[js/pdfjs/build/pdf.worker.js.map] => Array
[expected] => 6dea795c3fc20801ac14e3d54ce7c4af9bf29ef758e656576f88c459e133314a2c440f58c2953bde8b2011b355cfb53a867344480e76b2587ee6bb017adf2368
[current] => c2a3a6bf8c0bbd765d04c3e37f6fbce4d2f4926e78913e8bd739cfb883ed89ca65b6f6c84495fc610bc3439fd13f8fac2f466d75c82851a02cb4ee2a7b545c82
wwe: close old topics
