Issue when i click on 3dots while photo is opened
hello,
using latest firefox and nextcloud 24.0.4. when i open photo (not in photo album section) and i click on 3 dots in right up corner … the menu goes somewhere its not visible …
i need to zoom in/out page… then it shows on proper area… any idea?
Maybe you find some informations with firefox dev tools (F12). Also you can upgrade to Nextcloud 24.0.5.
@devnull
hello upgraded to 24.0.5, same issue ;(
In Nextcloud 25 is a photo app improved: Photos 2.0 .
Announcing Nextcloud Hub 3 – Brand New Design and Photos 2.0 with Editor and AI
Maybe it solves your problem.
okay
but its still not stable release right? thanks
Nextcloud 25.0.0 is Stable. Changelog - Nextcloud
But the distribution runs over a few weeks. If you want to force it you have to switch to channel “Beta”, upgrade and then switch back to channel “Stable”. But maybe wait a little bit longer. By the way, companies usually wait at least until the first point release (or the next release :wink: ).
If you work productively with Nextcloud it would be good if you had a similar test system. There you could try out Nextcloud 25 without danger. Maybe Photos 2.0 helps you or not.
