First i installed RASPOS64 lite at a 32GB SDcard (SSH enabled).
I did some initial configuration with raspi-config (wait for network, languages, wifi country, resizing the sdcard usage). But NO apt update/upgrade (coz this made the install of nextcloudpi fail).
Second i used for installation according to the nextcloudpi.com site
curl -sSL https://raw.githubusercontent.com/nextcloud/nextcloudpi/master/install.sh | bash
This install process went fine (without apt updat/upgrade). No issues.
Next i figured out i had to modify the config.php file (add the [fixed] local ip address). Done.
Third step was going to https://“local ip address” for initial setup. I had to bypass the chrome alert and ended up at the login page, NOT the set-up wizard.
Does anyone knows how to get tot the set-up wizard now???
Also the https://“local ip address”:4443 was not accessible. Connection refused.
I remembered my first install of ncp a long time ago and tried the user ncp with the traditional password and was able to login to the system. All seems to work. I can add my default user for nextcloud as an admin.
