Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
Nextcloud version (eg, 12.0.2):
Operating system and version (eg, Ubuntu 17.04):
PHP version (eg, 7.1):
Unable to connect to nextpi through SSH. When it comes to log in, I get putty fatal error âDisconnected: no supported authentication methods available (server sent: public key)â
I have been trying to find help with this issue and nothing has worked so far. Please help.
Is this the first time youâve seen this error? (Y/N):
No
- SSH using putty
- at login enter any login name
- it does not work because I get the above error
PASTE HERE "I would love to get that, but I can't."
PASTE HERE
PASTE HERE
