example
longer
example
here
Nextcloud version (eg, 29.0.5): replace me
Operating system and version (eg, Ubuntu 29.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 8.3): replace me
Lot of times, I needed to scp using winscp etc., reference to drive. it is unique challenge with nextcloud because you can access files only through c:\users<username>\nextcloud.
I was wondering if there was a way client would setup the nextcloud share using drive letter in windows explorer?
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
