Hello AIO developers and administrators,
Question:
Is there a difference between the AIO-image on Docker HUB (nextcloud/all-in-one:latest) and Github Container Registry (ghcr.io/nextcloud-releases/all-in-one:latest) or are they the same?
Thanks in advance!
Hi, they are the same. ghcr.io is the recommended one because no pull limits are applied to that one compared to docker hub.
Thanks!!
Can I replace ‘nextcloud/all-in-one:latest’ with ‘ghcr.io/nextcloud-releases/all-in-one:latest’ or will this create a whole new set of containers instead of replacing them?
Yes you can replace it. It should reuse the existing config.
Ah, thank you very much
I first used NAIO behind a reverse proxy (Apache), but now I run it directly. Is this possible or is the still some lingering configuration in one of the volumes that I have to adjust?
This post and the post with the title Can’t open port 443 (seems to be in limbo) - RHEL 9.4 are related.
