I’ve read some stuff that says it isn’t possible, but I’m honestly not too sure.
I tried dabbling with running a Collabora docker instance behind a Caddy proxy, but that was giving errors that I’ll have to try to solve some other time(sorry for not listing the specifics
On a side note, should I just not use the snap to avoid future headaches, and just install manually(not sure if this all is somehow related to the snap…)? Any inputs on that are appreciated as well.
