iPadOS CalDav/CardDav login on instance using Oauth2
Nextcloud version: 23.0.9, 24.0.5
Operating system and version : iPadOS 15.7
The issue you are facing: I can’t add my Nextcloud calendar/contacts as a CardDav/CalDav account on iPadOS using a Nextcloud instance with Oauth2 authentication.
This is because I do not get an authentication redirect to my Oauth2 provider.
Is this the first time you’ve seen this error?: Yes. I did not try this with an iPad before.
  1. Use a Nextcloud instance with Oauth2 as authentication
  2. Try to log in with your Oauth2 provider credentials
  3. It fails as expected, as Nextcloud cannot authenticate you
Login failed: '[user name redacted]' (Remote IP: '[redacted]')
Additional info
On Android, the Nextcloud app has a „Add contact/calendar“ function (in the settings) that sets up Davx5 appropriately. This works with an instance using Oauth2.
On iPadOS, the Nextcloud app does not have a similar option. Is it possible to do this in a different way?
You always have the option to set-up app specific passwords manually which should also work with iOS devices.
https://docs.nextcloud.com/server/latest/user_manual/en/groupware/sync_ios.html
https://docs.nextcloud.com/server/latest/user_manual/en/session_management.html
Thank you! Using an app password worked perfectly.
