Hi everyone,
I have deployed nextcloud on my server, using caddy2 as reverse proxy. I am including my docker-compose below. Everything was working fine and when I turned https on, I lost access from my iphone devices. When I try to connect either from the NextCloud app or from safari, I get NSURLErrorDomain: cannot parse response.
I know it is related to the reverse proxy, and that there are solutions for nginx. Has anyone found a solution for this problem for Caddy?
Thanks!
services:
proxy:
image: wemakeservices/caddy-gen:latest
container_name: proxy
restart: on-failure
depends_on:
- service
ports:
- "80:80"
- "443:443"
volumes:
- /var/run/docker.sock:/tmp/docker.sock:ro # Docker events
- proxy_data:/data/caddy
drive:
image: nextcloud:21.0.1
container_name: drive
depends_on:
- drive-db
restart: on-failure
volumes:
- drive_data:/var/www/html
ports:
- 9000:80
environment:
- MYSQL_HOST=drive-db
- MYSQL_DATABASE=$DRIVE_DB_NAME
- MYSQL_USER=$DRIVE_DB_USER
- MYSQL_PASSWORD=$DRIVE_DB_PASS
labels:
virtual.host: drive.$PROXY_DOMAIN # Domain name the service should live under
virtual.tls: $PROXY_EMAIL # Enable HTTPS
# Database used by `drive` service
drive-db:
image: mariadb:10.5.9
container_name: drive-db
restart: on-failure
volumes:
- drive-db_data:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=$DRIVE_DB_PASS_ADMIN
