iOS 15.5
Nextcloud client app version 4.4.0.18
Nextcloud Server 22.2.0
Problem:
If access happens via iOS “Files”, the nextcloud folder contains just one very old file inside. Neither actual folders nor files are inside the nextcloud folder.
If I try to delete this old file, it is “deleted” - all nextcloud folder is empty. But after that, if I leave the nextcloud folder, the all nextcloud folder is not visible anymore the “file” app.
After “file” app force-restart, the nextcloud folder and the old file inside are back.
All handling direct within the nextcloud app is ok, all working.
I already removed and re-installed all app. Disabled/Enabled the nextcloud app integration, restarted iPhone - nothing helped.
