After upgrading to 26.0.0 I recieve an internal error related to OCP\AppFramework\Db\Mapper\ not being found. This module was deprecated in NC26. However, now I’m facing an internal server error, and I have no idea how to fix it :-/ any idea what this error might be related to? How could I fix it?
{"reqId":"i3wx2nd6OG9ODL6BZoMK","level":3,"time":"2023-04-07T15:13:35+00:00","remoteAddr":"2a02:8071:2c81:5b60:7654:60c4:5c09:952f","user":"root","app":"index","method":"GET","url":"/index.php/apps/theming/image/logo?v=41","message":"Class \"OCP\\AppFramework\\Db\\Mapper\" not found","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36","version":"26.0.0.11","exception":{"Exception":"Error","Message":"Class \"OCP\\AppFramework\\Db\\Mapper\" not found","Code":0,"Trace":[{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/composer/composer/ClassLoader.php","line":578,"function":"include"},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/composer/composer/ClassLoader.php","line":432,"function":"Composer\\Autoload\\{closure}","class":"Composer\\Autoload\\ClassLoader","type":"::","args":["*** sensitive parameters replaced ***"]},{"function":"loadClass","class":"Composer\\Autoload\\ClassLoader","type":"->","args":["OCA\\Richdocuments\\Db\\WopiMapper"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"__construct","class":"ReflectionClass","type":"->","args":["OCA\\Richdocuments\\Db\\WopiMapper"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":142,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\Db\\WopiMapper"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":493,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\Db\\WopiMapper"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Richdocuments\\Db\\WopiMapper"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":97,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Richdocuments\\Db\\WopiMapper",true]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"array_map","args":[["Closure"],[["ReflectionParameter","rootFolder"],["ReflectionParameter","shareManager"],["ReflectionParameter","urlGenerator"],["ReflectionParameter","wopiParser"],["ReflectionParameter","capabilitiesService"],["ReflectionParameter","UserId"],"*** sensitive parameters replaced ***",["ReflectionParameter","trans"],["ReflectionParameter","helper"],["ReflectionParameter","permissionManager"]]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":124,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[["ReflectionClass","OCA\\Richdocuments\\TokenManager"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":142,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\TokenManager"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":493,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\TokenManager"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Richdocuments\\TokenManager"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":97,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Richdocuments\\TokenManager",true]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"array_map","args":[["Closure"],[["ReflectionParameter","cacheFactory"],["ReflectionParameter","clientService"],["ReflectionParameter","logger"],"*** sensitive parameters replaced ***",["ReflectionParameter","appConfig"],["ReflectionParameter","request"],["ReflectionParameter","urlGenerator"]]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":124,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[["ReflectionClass","OCA\\Richdocuments\\Service\\FederationService"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":142,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\Service\\FederationService"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":493,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\Service\\FederationService"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Richdocuments\\Service\\FederationService"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":97,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Richdocuments\\Service\\FederationService",true]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"array_map","args":[["Closure"],[["ReflectionParameter","request"],["ReflectionParameter","config"],["ReflectionParameter","appManager"],"*** sensitive parameters replaced ***",["ReflectionParameter","globalScaleConfig"]]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":124,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[["ReflectionClass","OCA\\Richdocuments\\Listener\\CSPListener"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Utility/SimpleContainer.php","line":142,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\Listener\\CSPListener"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":493,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Richdocuments\\Listener\\CSPListener"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/ServerContainer.php","line":155,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Richdocuments\\Listener\\CSPListener"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/EventDispatcher/ServiceEventListener.php","line":70,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCA\\Richdocuments\\Listener\\CSPListener"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":251,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->","args":[["OCP\\Security\\CSP\\AddContentSecurityPolicyEvent"],"OCP\\Security\\CSP\\AddContentSecurityPolicyEvent",["Symfony\\Component\\EventDispatcher\\EventDispatcher"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[[["Closure"],["Closure"]],"OCP\\Security\\CSP\\AddContentSecurityPolicyEvent",["OCP\\Security\\CSP\\AddContentSecurityPolicyEvent"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/EventDispatcher/EventDispatcher.php","line":87,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[["OCP\\Security\\CSP\\AddContentSecurityPolicyEvent"],"OCP\\Security\\CSP\\AddContentSecurityPolicyEvent"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/EventDispatcher/EventDispatcher.php","line":99,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["OCP\\Security\\CSP\\AddContentSecurityPolicyEvent",["OCP\\Security\\CSP\\AddContentSecurityPolicyEvent"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/Security/CSP/ContentSecurityPolicyManager.php","line":60,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":[["OCP\\Security\\CSP\\AddContentSecurityPolicyEvent"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Middleware/Security/CSPMiddleware.php","line":70,"function":"getDefaultPolicy","class":"OC\\Security\\CSP\\ContentSecurityPolicyManager","type":"->","args":[]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Middleware/MiddlewareDispatcher.php","line":142,"function":"afterController","class":"OC\\AppFramework\\Middleware\\Security\\CSPMiddleware","type":"->","args":[["OCA\\Theming\\Controller\\ThemingController"],"getImage",["OCP\\AppFramework\\Http\\FileDisplayResponse"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/Http/Dispatcher.php","line":175,"function":"afterController","class":"OC\\AppFramework\\Middleware\\MiddlewareDispatcher","type":"->","args":[["OCA\\Theming\\Controller\\ThemingController"],"getImage",["OCP\\AppFramework\\Http\\FileDisplayResponse"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/AppFramework/App.php","line":183,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Theming\\Controller\\ThemingController"],"getImage"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Theming\\Controller\\ThemingController","getImage",["OC\\AppFramework\\DependencyInjection\\DIContainer"],["logo","theming.Theming.getImage"]]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/lib/base.php","line":1055,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/theming/image/logo"]},{"file":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/vhosts/hosting154271.a2ed6.netcup.net/cloud.xxx.de/apps/richdocuments/lib/Db/WopiMapper.php","Line":35,"CustomMessage":"--"}}
