Hi
I’m running nexcloud 27.1.4 on an shared ovh server
My aim is opening and sharing libreoffice document.
I followed these steps, but unfortunately, I got an error dowmloading community document server. Here is what I found on log : “/appinfo/app.php is deprecaed, use /OCP/AppFramework/Bootstrap/Bootstrap on the application class instead”
Thanks for helping
Hi
I suppress office online integration and now, it asked me for a password and gave me this error. I’m however sure of my password
short for a generated token, should be the password during basic auth
/home/infoadre/www/nextcloud/lib/private/Authentication/Token/Manager.php - line 133:
OC\Authentication\Token\PublicKeyTokenProvider->getToken(“*** sensiti … “)
/home/infoadre/www/nextcloud/lib/private/User/Session.php - line 528:
OC\Authentication\Token\Manager->getToken(”** sensiti … “)
/home/infoadre/www/nextcloud/lib/private/User/Session.php - line 438:
OC\User\Session->isTokenPassword(”** sensiti … “)
/home/infoadre/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php - line 114:
OC\User\Session->logClientIn(”** sensiti … “)
/home/infoadre/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php - line 103:
OCA\DAV\Connector\Sabre\Auth->validateUserPass(”** sensiti … *”)
/home/infoadre/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php - line 232:
Sabre\DAV\Auth\Backend\AbstractBasic->check([ “Sabre\HTTP\Request”], [ “Sabre\HTTP\Response”])
/home/infoadre/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php - line 139:
OCA\DAV\Connector\Sabre\Auth->auth([ “Sabre\HTTP\Request”], [ “Sabre\HTTP\Response”])
/home/infoadre/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php - line 179:
OCA\DAV\Connector\Sabre\Auth->check([ “Sabre\HTTP\Request”], [ “Sabre\HTTP\Response”])
/home/infoadre/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php - line 135:
Sabre\DAV\Auth\Plugin->check([ “Sabre\HTTP\Request”], [ “Sabre\HTTP\Response”])
/home/infoadre/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:
Sabre\DAV\Auth\Plugin->beforeMethod([ “Sabre\HTTP\Request”], [ “Sabre\HTTP\Response”])
/home/infoadre/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 456:
Sabre\DAV\Server->emit(“beforeMethod:PROPFIND”, [ [ “Sabre\ … ]])
/home/infoadre/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 253:
Sabre\DAV\Server->invokeMethod([ “Sabre\HTTP\Request”], [ “Sabre\HTTP\Response”])
/home/infoadre/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 321:
Sabre\DAV\Server->start()
/home/infoadre/www/nextcloud/apps/dav/lib/Server.php - line 365:
Sabre\DAV\Server->exec()
/home/infoadre/www/nextcloud/apps/dav/appinfo/v2/remote.php - line 35:
OCA\DAV\Server->exec()
/home/infoadre/www/nextcloud/remote.php - line 172:
require_once(”/home/infoa … p")
