Hi there,
I am trying to install nextcloud using
curl -sSL https://raw.githubusercontent.com/nextcloud/nextcloudpi/master/install.sh | sudo bash
On a fresh Raspi OS, this worked like a charm and the configuration wizard came up.
Recently, I re-flashed the Raspi OS and setup Pi-Hole and Wireguard.
Now, the installation of Nextcloud does not complete and ends with
Site nextcloud disabled.
To activate the new configuration, you need to run:
systemctl reload apache2
Site ncp-activation already enabled
New password: Retype new password: passwd: password updated successfully
Downloading updates
Performing updates
/usr/local/etc/library.sh: line 263: [: v0: integer expression expected
/usr/local/etc/library.sh: line 265: [: v0: integer expression expected
/usr/local/etc/library.sh: line 267: [: v0: integer expression expected
There are no commands defined in the “config:system” namespace.
Running nc-init
Setting up a clean Nextcloud instance… wait until message ‘NC init done’
Setting up database…
Setting up Nextcloud…
Set an admin password.
When trying to manually reload apache2, I get the following message:
pi@raspberrypi:~ $ systemctl reload apache2
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to reload ‘apache2.service’.
Authenticating as: , (pi)
Password:
==== AUTHENTICATION COMPLETE ===
apache2.service is not active, cannot reload.
So I guess the existing Pi-Hole and/or Wireguard-Installations interfere with apache2?!
Any ideas about that are greatly appreciated!
