you have putty installed? you can ssh into your vm?
I dont have putty installed?..
Now i have it, what do i do?
On windows 10 you can open the command prompt and use ssh from there:
ssh ncadmin@localipaddress
should work.
connect to your vm. you need the ip address and user/password. to you have it?
I have it both
ncadmin
nextcloud
so login to the server.
My other VM has internet access so i dont know why it should be a problem now
I am in this step now but i cant type @ in it?
so you have an error in network definition.
i can’t you help you out here. it might be vmware related. @enoch85 daniel might know. or google.
i would say: don’t care. or check if the vm uses the english/us keyboard layout. in germany i would press z and woudl get an y on the screen if keyboard layout is a problem.
I guess in this case is your keyboard layout not correct. You should have seen an option ro change the layout during the initial setup.
