Installation issues with Nextcloud and flow engine
    • 32.0.5
    • TrueNAS 25.10.1 - Goldeye
    • replace me
      • nginx 2.13.7
    • replace me
    • yes
    When did this problem seem to first start?
    • Fresh Install on 8 Feb 2026
    • Custom Apps on TrueNAS
Fresh custom app TrueNAS install of Nextcloud + aio-talk + nextcloud-appapi-harp + flow
Open flow app
Synchronize Hub Resource types with instance
Errors pop up
mariadb:10.6
  1. Fresh install of Nextcloud + aio-talk + nextcloud-appapi-harp + flow
  2. Configure AppAPI
  3. Verify Deamon Connection Successful
  4. Verify Deploy test checks must be passed to succeed: (6 / 6)
  5. Install flow Tutorial: Install 1.2.0 (newer version is broken) · Issue #132 · nextcloud/flow
  6. Open workflow engine , select the admins workspace, select Synchronize Hub Resource types with instance to populate resources.
  7. Get ApiErro and database “queue” error
None
None
PASTE HERE
root@d9299d8854c4:/# occ config:list
            "my.domain.com"
        "dbtype": "mysql",
        "version": "32.0.5.0",
        "overwrite.cli.url": "https:\/\/192.168.1.10:8887",
        "mysql.utf8mb4": true,
        "filelocking.enabled": true,
        "memcache.locking": "\\OC\\Memcache\\APCu",
        "upgrade.disable-web": true
    "apps": {
        "activity": {
            "enabled": "yes",
            "installed_version": "5.0.0-dev.0",
            "types": "filesystem"
        "app_api": {
            "enabled": "yes",
            "installed_version": "32.0.0",
            "types": "",
            "default_daemon_config": "harp_proxy_docker"
        "backgroundjob": {
            "lastjob": "125"
        "bruteforcesettings": {
            "enabled": "yes",
            "types": ""
        "calendar": {
            "enabled": "yes",
            "installed_version": "6.1.6",
            "types": ""
        "circles": {
            "enabled": "yes",
            "loopback_tmp_scheme": "https",
            "maintenance_run": "0",
            "maintenance_update": "{\"3\":1770693601,\"2\":1770694201,\"1\":1770694500}",
            "types": "filesystem,dav"
        "cloud_federation_api": {
            "enabled": "yes",
            "installed_version": "1.16.0",
        "comments": {
            "enabled": "yes",
            "installed_version": "1.22.0",
            "types": "logging"
        "contactsinteraction": {
            "enabled": "yes",
            "installed_version": "1.13.1",
            "types": "dav"
        "core": {
            "backgroundjobs_mode": "cron",
            "installedat": "1770577597.3325",
            "lastcron": 1770694502,
            "lastupdateResult": "[]",
            "lastupdatedat": 1770694006,
            "metadataGenerationDone": true,
            "public_files": "files_sharing\/public.php",
            "vendor": "nextcloud",
            "files_metadata": {
                "photos-original_date_time": {
                    "value": null,
                    "type": "int",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "photos-exif": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-ifd0": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-size": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "blurhash": {
                    "value": null,
                    "type": "string",
                    "etag": "2bbdbd27d7a6891a3f4896b2896bf3c9",
                    "indexed": false,
                    "editPermission": 0
            "oc.integritycheck.checker": []
        "dashboard": {
            "enabled": "yes",
            "installed_version": "7.12.0",
            "types": ""
        "dav": {
            "enabled": "yes",
            "hasCustomDefaultContact": false,
            "installed_version": "1.34.2",
        "federatedfilesharing": {
            "enabled": "yes",
            "types": ""
        "federation": {
            "enabled": "yes",
            "types": "authentication"
        "files": {
            "enabled": "yes",
            "installed_version": "2.4.0",
        "files_downloadlimit": {
            "enabled": "yes",
            "types": ""
        "files_pdfviewer": {
            "enabled": "yes",
            "types": ""
        "files_reminders": {
            "enabled": "yes",
            "installed_version": "1.5.0",
            "types": ""
        "files_sharing": {
            "enabled": "yes",
            "installed_version": "1.24.1",
        "files_trashbin": {
            "enabled": "yes",
        "files_versions": {
            "enabled": "yes",
            "installed_version": "1.25.0",
        "firstrunwizard": {
            "enabled": "yes",
            "types": ""
        "logreader": {
            "enabled": "yes",
            "types": "logging"
        "lookup_server_connector": {
            "enabled": "yes",
            "installed_version": "1.20.0",
        "nextcloud_announcements": {
            "enabled": "yes",
            "installed_version": "4.0.0-dev.0",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
            "types": "logging"
        "notifications": {
            "enabled": "yes",
            "types": "logging"
        "oauth2": {
            "enabled": "yes",
        "password_policy": {
            "enabled": "yes",
        "photos": {
            "enabled": "yes",
            "installed_version": "5.0.0-dev.1",
            "lastPlaceMappedUser": "admin",
            "lastPlaceMappingDone": "true",
            "types": "dav,authentication"
        "privacy": {
            "enabled": "yes",
            "types": ""
        "profile": {
            "enabled": "yes",
            "installed_version": "1.1.0",
            "types": ""
        "provisioning_api": {
            "enabled": "yes",
            "types": "prevent_group_restriction"
        "recommendations": {
            "enabled": "yes",
            "types": ""
        "related_resources": {
            "enabled": "yes",
            "installed_version": "3.0.0-dev.0",
            "types": ""
        "richdocuments": {
            "disable_certificate_verification": "",
            "enabled": "yes",
            "installed_version": "9.0.2",
            "public_wopi_url": "https:\/\/my.domain.com",
            "types": "filesystem,prevent_group_restriction",
            "wopi_url": "https:\/\/my.domain.com"
        "richdocumentscode": {
            "enabled": "no",
            "installed_version": "25.4.802",
            "types": ""
        "serverinfo": {
            "cached_count_appdata_files": 214,
            "cached_count_filecache": 285,
            "cached_count_storages": 2,
            "enabled": "yes",
            "size_appdata_storage": 5285178,
            "types": ""
        "settings": {
            "enabled": "yes",
            "installed_version": "1.15.1",
            "types": ""
        "sharebymail": {
            "enabled": "yes",
        "spreed": {
            "enabled": "yes",
            "installed_version": "22.0.8",
            "signaling_servers": "***REMOVED SENSITIVE VALUE***",
            "signaling_token_privkey_es256": "***REMOVED SENSITIVE VALUE***",
            "signaling_token_pubkey_es256": "***REMOVED SENSITIVE VALUE***",
            "stun_servers": "***REMOVED SENSITIVE VALUE***",
            "turn_servers": "***REMOVED SENSITIVE VALUE***",
            "types": "dav,prevent_group_restriction"
        "support": {
            "enabled": "yes",
            "types": "session"
        "survey_client": {
            "enabled": "yes",
            "types": ""
        "systemtags": {
            "enabled": "yes",
            "types": "logging"
        "text": {
            "enabled": "yes",
            "installed_version": "6.0.1",
            "types": "dav"
        "theming": {
            "enabled": "yes",
            "installed_version": "2.7.0",
            "types": "logging"
        "twofactor_backupcodes": {
            "enabled": "yes",
            "installed_version": "1.21.0",
            "types": ""
        "updatenotification": {
            "calendar": "6.2.0",
            "enabled": "yes",
            "types": "",
            "update_check_errors": 0
        "user_status": {
            "enabled": "yes",
            "installed_version": "1.12.0",
            "types": ""
        "viewer": {
            "enabled": "yes",
            "types": ""
        "weather_status": {
            "enabled": "yes",
            "types": ""
        "webhook_listeners": {
            "enabled": "yes",
            "installed_version": "1.3.0",
        "workflowengine": {
            "enabled": "yes",
            "installed_version": "2.14.0",
Resolved : Issue was corrected with adding missing permissions to the storage dataset and reinstalling the flow app.
