Nextcloud version 29.0.0
Operating system and version: Almalinux 9.4
Apache 2.4.57
PHP version 8.3.6
I’m trying to set up Openproject in an isolated environment with Nextcloud. They are running on separate VMs on the same subnet, and are NOT running in containers. I’m following the integration instructions found here: https://www.openproject.org/docs/system-admin-guide/integrations/nextcloud/ They are using an internal self signed certificate and there is a copy of the certificate bundle in /etc/ssl/certs/ca-bundle.crt (this is a symlink to /etc/pki/ca-trust/extracted/pem/tls-ca-bundle.pem).
When I enter the OpenPoject host url in the nectcloud openproject app I receive a curl error.
Is there another location the certificate bundle needs to be placed? Any advice is appreciated
Nc uses its own (well, sort of: it’s from cURL, technically). The commands are here. The documentation on this topic could probably use some improvement.
For future reference. I first had to make the ca-bundle.crt file available to occ. In my test I copied it to a new folder in /var/www/nextcloud/resources/ssl and updated its ownership and file permissions. Then I ran sudo -u apache php occ security:certificates:import /var/www/nextcloud/resouces/ssl/ca-bundle.crt and verified that it was imported by listing the ssl certs, occ security:certificate.
I was then able to connect to my openproject instance in the GUI.
It’s not a high priority item for me personally so I’m unlikely to pick it up anytime in the near future. But maybe someone else feels like getting into it.
P.S. Docs can be contributed to by anyone. Just click “Edit on GitHub” while viewing. Maybe someone reading this post one day in the future feels like getting the ball rolling.
I would be very surprised if you didn’t run into the very same issue on the side of OpenProject. I.e. the OpenProject integration trying to make requests against NextCloud will fail all the same if you are using a self-signed certificate.
To fix that you will have to configure the ca bundle for OpenProject as well.
This done via the SSL_CERT_FILE environment variable.
So if you are using a VM with OpenProject’s package installation, you could set that as follows.
Follow up question since you’ve all been so helpful. I was surprised that occ wasnt able to import the ca-bundle when it was located in /etc/pki/tls/certs/. The import command returns " Certificate not found, please provide a path accessible by the web server user"
I tried updating file permissions to 777 and giving apache explicit access using setfacl -m -u :apache:rw /etc/pki/tls/certs/ca-bundle.crt, but the import still fails. Does occ have a more limited view of the filesystem then I’m expecting? Any thoughts?
Thanks jtr, heres what I found. It looks like there is a constraint set.
PHP Warning: file_exists(): open_basedir restriction in effect. File(/etc/pki/tls/certs/ca-bundle.crt) is not within the allowed path(s): (/var/www/nextcloud:/var/www/ncdata:/run/redis/redis.sock:/proc/cpuinfo:/proc/meminfo:/dev/urandom:/tmp:/usr/bin/clamscan:/dev/dri:/run/docker.sock) in Command line code on line 1
bool(false)
I don’t have a lot of experience working with php but I did find the following constraint in the /etc/php.ini file.
; open_basedir, if set, limits all file operations to the defined directory
; and below. This directive makes most sense if used in a per-directory
; or per-virtualhost web server configuration file.
; Note: disables the realpath cache
; https://php.net/open-basedir
open_basedir = /var/www/nextcloud:/var/www/ncdata:/run/redis/redis.sock:/proc/cpuinfo:/proc/meminfo:/dev/urandom:/tmp:/usr/bin/clamscan:/dev/dri:/run/docker.sock
