- 30.0.4
- Debian 12
- NGINX 1.22.1-9
- NGINX 1.22.1-9
- PHP version (e.g, 8.3):
- 8.3
- No
- Don’t know
- Installation script
- No
The installation fails for a reason i couldn’t identify.
- Execute the install script (the script commands are visible in the log)
args:
app: nextcloud
force: false
label: Cloud
no_remove_on_failure: false
ended_at: 2025-01-05 20:48:03.397804
env:
YNH_APP_ACTION: install
YNH_APP_ARG_ADMIN: stemy
YNH_APP_ARG_DOMAIN: cloud.maindomain.tld
YNH_APP_ARG_INIT_MAIN_PERMISSION: visitors
YNH_APP_ARG_PATH: /
YNH_APP_ARG_USER_HOME: '1'
YNH_APP_BASEDIR: /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz
YNH_APP_ID: nextcloud
YNH_APP_INSTANCE_NAME: nextcloud
YNH_APP_INSTANCE_NUMBER: '1'
YNH_APP_MANIFEST_VERSION: 30.0.4~ynh2
YNH_APP_PACKAGING_FORMAT: '2.0'
YNH_ARCH: arm64
YNH_DEBIAN_VERSION: bookworm
YNH_DEFAULT_PHP_VERSION: '8.2'
YNH_HELPERS_VERSION: '2.1'
error: 'Une erreur est survenue dans le script d''installation de l''application :
Unable to install nextcloud'
interface: api
operation: app_install
parent: null
related_to:
- - app
- nextcloud
started_at: 2025-01-05 20:36:04.134743
success: false
yunohost_version: 12.0.9.1
2025-01-05 20:36:04,519: INFO - Installation de nextcloud…
2025-01-05 20:36:04,527: INFO - Provisioning sources...
2025-01-05 20:36:04,529: DEBUG - Prefetching asset main: https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 ...
2025-01-05 20:39:28,959: INFO - Provisioning system_user...
2025-01-05 20:39:36,384: INFO - Provisioning install_dir...
2025-01-05 20:39:36,391: INFO - Provisioning data_dir...
2025-01-05 20:39:36,399: INFO - Provisioning permissions...
2025-01-05 20:39:39,303: DEBUG - Permission 'nextcloud.main' mise à jour
2025-01-05 20:39:39,305: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203938-permission_url-nextcloud" style="text-decoration :underline"> Mise à jour de l'URL associée à l'autorisation 'nextcloud' </a>'
2025-01-05 20:39:39,935: DEBUG - Permission 'nextcloud.main' créée
2025-01-05 20:39:39,935: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203936-permission_create-nextcloud" style="text-decoration :underline"> Créer permission 'nextcloud' </a>'
2025-01-05 20:39:39,974: DEBUG - Permission 'nextcloud.main' mise à jour
2025-01-05 20:39:39,975: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203939-user_permission_update-nextcloud" style="text-decoration :underline"> Mise à jour des accès pour la permission 'nextcloud' </a>'
2025-01-05 20:39:39,991: DEBUG - Nothing to update in LDAP
2025-01-05 20:39:39,991: DEBUG - Permission 'nextcloud.main' mise à jour
2025-01-05 20:39:39,993: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203939-permission_url-nextcloud" style="text-decoration :underline"> Mise à jour de l'URL associée à l'autorisation 'nextcloud' </a>'
2025-01-05 20:39:41,771: DEBUG - Permission 'nextcloud.api' mise à jour
2025-01-05 20:39:41,774: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203941-permission_url-nextcloud" style="text-decoration :underline"> Mise à jour de l'URL associée à l'autorisation 'nextcloud' </a>'
2025-01-05 20:39:42,966: DEBUG - Permission 'nextcloud.api' créée
2025-01-05 20:39:42,967: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203939-permission_create-nextcloud" style="text-decoration :underline"> Créer permission 'nextcloud' </a>'
2025-01-05 20:39:43,009: DEBUG - Permission 'nextcloud.api' mise à jour
2025-01-05 20:39:43,009: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203942-user_permission_update-nextcloud" style="text-decoration :underline"> Mise à jour des accès pour la permission 'nextcloud' </a>'
2025-01-05 20:39:43,024: DEBUG - Nothing to update in LDAP
2025-01-05 20:39:43,024: DEBUG - Permission 'nextcloud.api' mise à jour
2025-01-05 20:39:43,026: DEBUG - Journal complet de cette opération : '<a href="#/tools/logs/20250105-203943-permission_url-nextcloud" style="text-decoration :underline"> Mise à jour de l'URL associée à l'autorisation 'nextcloud' </a>'
2025-01-05 20:39:44,869: DEBUG - The permission database has been resynchronized
2025-01-05 20:39:44,936: DEBUG - La configuration de SSOwat a été regénérée
2025-01-05 20:39:44,944: INFO - Provisioning apt...
2025-01-05 20:39:44,952: DEBUG - Executing command '['sh', '-c', '/bin/bash -x "./provision_or_update_apt" 7>&1']'
2025-01-05 20:39:44,955: DEBUG - + source /usr/share/yunohost/helpers
2025-01-05 20:39:44,956: DEBUG - ++++ dirname -- /usr/share/yunohost/helpers
2025-01-05 20:39:44,956: DEBUG - +++ cd -- /usr/share/yunohost
2025-01-05 20:39:44,956: DEBUG - +++ pwd
2025-01-05 20:39:44,957: DEBUG - ++ SCRIPT_DIR=/usr/share/yunohost
2025-01-05 20:39:44,957: DEBUG - ++ YNH_HELPERS_VERSION=2.1
2025-01-05 20:39:44,958: DEBUG - ++ readonly 'XTRACE_ENABLE=set -o xtrace'
2025-01-05 20:39:44,958: DEBUG - ++ XTRACE_ENABLE='set -o xtrace'
2025-01-05 20:39:44,970: DEBUG - + ynh_abort_if_errors
2025-01-05 20:39:44,971: DEBUG - + trap ynh_exit_properly EXIT
2025-01-05 20:39:44,971: DEBUG - + ynh_apt_install_dependencies mariadb-server imagemagick libmagickcore-6.q16-6-extra acl tar smbclient at redis-server php8.3-fpm php8.3-bz2 php8.3-imap php8.3-gmp php8.3-gd php8.3-intl php8.3-curl php8.3-apcu php8.3-redis php8.3-ldap php8.3-imagick php8.3-zip php8.3-mbstring php8.3-xml php8.3-mysql php8.3-igbinary php8.3-bcmath
2025-01-05 20:39:44,971: DEBUG - ++ sed 's/\([^\<=\>]\)\ \([^(]\)/\1, \2/g'
2025-01-05 20:39:44,972: DEBUG - ++ sed 's/|/ | /'
2025-01-05 20:39:44,974: DEBUG - + local 'dependencies=mariadb-server, imagemagick, libmagickcore-6.q16-6-extra, acl, tar, smbclient, at, redis-server, php8.3-fpm, php8.3-bz2, php8.3-imap, php8.3-gmp, php8.3-gd, php8.3-intl, php8.3-curl, php8.3-apcu, php8.3-redis, php8.3-ldap, php8.3-imagick, php8.3-zip, php8.3-mbstring, php8.3-xml, php8.3-mysql, php8.3-igbinary, php8.3-bcmath'
2025-01-05 20:39:44,974: DEBUG - ++ ynh_read_manifest version
2025-01-05 20:39:44,975: DEBUG - ++ cat /var/cache/yunohost/app_tmp_work_dirs/app_847_rpep/manifest.toml
2025-01-05 20:39:44,977: DEBUG - ++ toml_to_json
2025-01-05 20:39:44,977: DEBUG - ++ python3 -c 'import toml, json, sys; print(json.dumps(toml.load(sys.stdin)))'
2025-01-05 20:39:44,977: DEBUG - ++ jq .version --raw-output
2025-01-05 20:39:45,028: DEBUG - + local version=30.0.4~ynh2
2025-01-05 20:39:45,028: DEBUG - + local app_ynh_deps=nextcloud-ynh-deps
2025-01-05 20:39:45,028: DEBUG - + grep '[<=>]'
2025-01-05 20:39:45,030: DEBUG - ++ grep -oP '(?<=php)[0-9.]+(?=-|\>|)'
2025-01-05 20:39:45,031: DEBUG - ++ sort -u
2025-01-05 20:39:45,032: DEBUG - + local specific_php_version=8.3
2025-01-05 20:39:45,032: DEBUG - + [[ -n 8.3 ]]
2025-01-05 20:39:45,032: DEBUG - ++ echo 8.3
2025-01-05 20:39:45,032: DEBUG - ++ wc -l
2025-01-05 20:39:45,035: DEBUG - + [[ 1 -eq 1 ]]
2025-01-05 20:39:45,035: DEBUG - + dependencies+=', php8.3, php8.3-fpm, php8.3-common'
2025-01-05 20:39:45,035: DEBUG - ++ ynh_app_setting_get --key=php_version
2025-01-05 20:39:45,093: DEBUG - + local old_php_version=
2025-01-05 20:39:45,093: DEBUG - + '[' -n '' ']'
2025-01-05 20:39:45,094: DEBUG - + ynh_app_setting_set --key=php_version --value=8.3
2025-01-05 20:39:45,173: DEBUG - + test -e /usr/bin/php7.4
2025-01-05 20:39:45,173: DEBUG - ++ _ynh_apt_package_is_installed postgresql-13
2025-01-05 20:39:45,174: DEBUG - ++ local package=postgresql-13
2025-01-05 20:39:45,174: DEBUG - ++ dpkg-query --show '--showformat=${db:Status-Status}' postgresql-13
2025-01-05 20:39:45,174: DEBUG - ++ grep --quiet '^installed$'
2025-01-05 20:39:45,195: DEBUG - ++ echo no
2025-01-05 20:39:45,195: DEBUG - + local psql_installed=no
2025-01-05 20:39:45,195: DEBUG - + [[ true == \t\r\u\e ]]
2025-01-05 20:39:45,195: DEBUG - + YNH_APT_INSTALL_DEPENDENCIES_REPLACE=false
2025-01-05 20:39:45,195: DEBUG - ++ mktemp --directory
2025-01-05 20:39:45,196: DEBUG - + local TMPDIR=/tmp/tmp.Yql32ejQ8J
2025-01-05 20:39:45,196: DEBUG - + mkdir -p /tmp/tmp.Yql32ejQ8J/nextcloud-ynh-deps/DEBIAN
2025-01-05 20:39:45,197: DEBUG - + chmod -R 755 /tmp/tmp.Yql32ejQ8J/nextcloud-ynh-deps
2025-01-05 20:39:45,198: DEBUG - + cat
2025-01-05 20:39:45,199: DEBUG - + _ynh_apt update
2025-01-05 20:39:45,199: DEBUG - + _ynh_wait_dpkg_free
2025-01-05 20:39:45,343: DEBUG - + return 0
2025-01-05 20:39:45,343: DEBUG - + apt-get --assume-yes --quiet -o=Acquire::Retries=3 -o=Dpkg::Use-Pty=0 update
2025-01-05 20:39:45,663: DEBUG - Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
2025-01-05 20:39:45,774: DEBUG - Hit:3 https://packages.sury.org/php bookworm InRelease
2025-01-05 20:39:45,892: DEBUG - Hit:4 http://deb.debian.org/debian bookworm InRelease
2025-01-05 20:39:45,952: DEBUG - Hit:1 https://forge.yunohost.org/debian bookworm InRelease
2025-01-05 20:39:45,955: DEBUG - Hit:5 http://deb.debian.org/debian-security bookworm-security InRelease
2025-01-05 20:39:45,990: DEBUG - Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
2025-01-05 20:39:46,005: DEBUG - Hit:7 https://dl.yarnpkg.com/debian stable InRelease
2025-01-05 20:39:47,998: DEBUG - Reading package lists...
2025-01-05 20:39:48,025: DEBUG - + _ynh_wait_dpkg_free
2025-01-05 20:39:48,177: DEBUG - + return 0
2025-01-05 20:39:48,178: DEBUG - + dpkg-deb --build /tmp/tmp.Yql32ejQ8J/nextcloud-ynh-deps /tmp/tmp.Yql32ejQ8J/nextcloud-ynh-deps.deb
2025-01-05 20:39:48,553: DEBUG - + dpkg --force-depends --install /tmp/tmp.Yql32ejQ8J/nextcloud-ynh-deps.deb
2025-01-05 20:39:48,553: DEBUG - + tee /tmp/tmp.Yql32ejQ8J/dpkg_log
2025-01-05 20:39:49,171: DEBUG - Selecting previously unselected package nextcloud-ynh-deps.
2025-01-05 20:39:49,248: DEBUG - (Reading database ... 149749 files and directories currently installed.)
2025-01-05 20:39:49,258: DEBUG - Preparing to unpack .../nextcloud-ynh-deps.deb ...
2025-01-05 20:39:49,270: DEBUG - Unpacking nextcloud-ynh-deps (30.0.4~ynh2) ...
2025-01-05 20:39:49,328: DEBUG - Setting up nextcloud-ynh-deps (30.0.4~ynh2) ...
2025-01-05 20:39:49,434: DEBUG - + _ynh_apt_install --fix-broken
2025-01-05 20:39:49,434: DEBUG - + _ynh_apt --no-remove --option Dpkg::Options::=--force-confdef --option Dpkg::Options::=--force-confold install --fix-broken
2025-01-05 20:39:49,434: DEBUG - + _ynh_wait_dpkg_free
2025-01-05 20:39:49,571: DEBUG - + return 0
2025-01-05 20:39:49,572: DEBUG - + apt-get --assume-yes --quiet -o=Acquire::Retries=3 -o=Dpkg::Use-Pty=0 --no-remove --option Dpkg::Options::=--force-confdef --option Dpkg::Options::=--force-confold install --fix-broken
2025-01-05 20:39:51,999: DEBUG - Reading package lists...
2025-01-05 20:39:52,446: DEBUG - Building dependency tree...
2025-01-05 20:39:52,448: DEBUG - Reading state information...
2025-01-05 20:39:53,109: DEBUG - 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
2025-01-05 20:39:53,110: DEBUG - + rm --recursive --force /tmp/tmp.Yql32ejQ8J
2025-01-05 20:39:53,112: DEBUG - + _ynh_apt_package_is_installed nextcloud-ynh-deps
2025-01-05 20:39:53,113: DEBUG - + local package=nextcloud-ynh-deps
2025-01-05 20:39:53,114: DEBUG - + dpkg-query --show '--showformat=${db:Status-Status}' nextcloud-ynh-deps
2025-01-05 20:39:53,114: DEBUG - + grep --quiet '^installed$'
2025-01-05 20:39:53,134: DEBUG - ++ _ynh_apt_package_is_installed postgresql-13
2025-01-05 20:39:53,135: DEBUG - ++ local package=postgresql-13
2025-01-05 20:39:53,136: DEBUG - ++ dpkg-query --show '--showformat=${db:Status-Status}' postgresql-13
2025-01-05 20:39:53,136: DEBUG - ++ grep --quiet '^installed$'
2025-01-05 20:39:53,156: DEBUG - ++ echo no
2025-01-05 20:39:53,156: DEBUG - + local psql_installed2=no
2025-01-05 20:39:53,157: DEBUG - + [[ no != \n\o ]]
2025-01-05 20:39:53,157: DEBUG - + ynh_exit_properly
2025-01-05 20:39:53,157: DEBUG - + [[ provision_or_update_apt =~ ^install$|^upgrade$|^restore$ ]]
2025-01-05 20:39:53,259: INFO - Provisioning database...
2025-01-05 20:39:53,505: DEBUG - Executing command '['sh', '-c', '/bin/bash -x "./provision_database" 7>&1']'
2025-01-05 20:39:53,507: DEBUG - + source /usr/share/yunohost/helpers
2025-01-05 20:39:53,508: DEBUG - ++++ dirname -- /usr/share/yunohost/helpers
2025-01-05 20:39:53,508: DEBUG - +++ cd -- /usr/share/yunohost
2025-01-05 20:39:53,508: DEBUG - +++ pwd
2025-01-05 20:39:53,508: DEBUG - ++ SCRIPT_DIR=/usr/share/yunohost
2025-01-05 20:39:53,508: DEBUG - ++ YNH_HELPERS_VERSION=2.1
2025-01-05 20:39:53,510: DEBUG - ++ readonly 'XTRACE_ENABLE=set -o xtrace'
2025-01-05 20:39:53,510: DEBUG - ++ XTRACE_ENABLE='set -o xtrace'
2025-01-05 20:39:53,522: DEBUG - + ynh_abort_if_errors
2025-01-05 20:39:53,523: DEBUG - + trap ynh_exit_properly EXIT
2025-01-05 20:39:53,523: DEBUG - + ynh_mysql_create_db nextcloud nextcloud **********
2025-01-05 20:39:53,523: DEBUG - + local db=nextcloud
2025-01-05 20:39:53,523: DEBUG - + local 'sql=CREATE DATABASE nextcloud;'
2025-01-05 20:39:53,523: DEBUG - + [[ 3 -gt 1 ]]
2025-01-05 20:39:53,524: DEBUG - + sql+=' GRANT ALL PRIVILEGES ON nextcloud.* TO '\''nextcloud'\''@'\''localhost'\'''
2025-01-05 20:39:53,524: DEBUG - + [[ -n ********** ]]
2025-01-05 20:39:53,524: DEBUG - + sql+=' IDENTIFIED BY '\''**********'\'''
2025-01-05 20:39:53,524: DEBUG - + sql+=' WITH GRANT OPTION;'
2025-01-05 20:39:53,524: DEBUG - + mysql -B
2025-01-05 20:39:53,533: DEBUG - + ynh_exit_properly
2025-01-05 20:39:53,534: DEBUG - + [[ provision_database =~ ^install$|^upgrade$|^restore$ ]]
2025-01-05 20:39:53,638: DEBUG - Executing command '['sh', '-c', '/bin/bash -x "./install" 7>&1']'
2025-01-05 20:39:53,640: DEBUG - + source _common.sh
2025-01-05 20:39:53,641: DEBUG - + source /usr/share/yunohost/helpers
2025-01-05 20:39:53,641: DEBUG - ++++ dirname -- /usr/share/yunohost/helpers
2025-01-05 20:39:53,641: DEBUG - +++ cd -- /usr/share/yunohost
2025-01-05 20:39:53,642: DEBUG - +++ pwd
2025-01-05 20:39:53,642: DEBUG - ++ SCRIPT_DIR=/usr/share/yunohost
2025-01-05 20:39:53,642: DEBUG - ++ YNH_HELPERS_VERSION=2.1
2025-01-05 20:39:53,643: DEBUG - ++ readonly 'XTRACE_ENABLE=set -o xtrace'
2025-01-05 20:39:53,643: DEBUG - ++ XTRACE_ENABLE='set -o xtrace'
2025-01-05 20:39:53,655: DEBUG - + ynh_app_setting_set --key=php_upload_max_filesize --value=10G
2025-01-05 20:39:53,742: DEBUG - + ynh_app_setting_set --key=php_memory_limit --value=512M
2025-01-05 20:39:54,087: DEBUG - + ynh_app_setting_set --key=fpm_footprint --value=high
2025-01-05 20:39:54,171: DEBUG - + ynh_app_setting_set --key=fpm_usage --value=medium
2025-01-05 20:39:58,280: DEBUG - + phpflags='--define apc.enable_cli=1'
2025-01-05 20:39:58,281: DEBUG - + ynh_app_setting_set --key=phpflags '--value=--define apc.enable_cli=1'
2025-01-05 20:39:59,381: DEBUG - + enable_notify_push=0
2025-01-05 20:39:59,382: DEBUG - + ynh_app_setting_set --key=enable_notify_push --value=0
2025-01-05 20:40:01,768: DEBUG - + system_addressbook_exposed=0
2025-01-05 20:40:01,768: DEBUG - + ynh_app_setting_set --key=system_addressbook_exposed --value=0
2025-01-05 20:40:02,915: INFO - [++..................] > Migrate MySQL database to utf8...
2025-01-05 20:40:02,921: DEBUG - + ynh_mysql_db_shell
2025-01-05 20:40:02,921: DEBUG - + local database=nextcloud
2025-01-05 20:40:02,921: DEBUG - + local default_character_set=
2025-01-05 20:40:02,921: DEBUG - + [[ -n nextcloud ]]
2025-01-05 20:40:02,921: DEBUG - ++ mysql -B nextcloud
2025-01-05 20:40:02,922: DEBUG - ++ cut -f2
2025-01-05 20:40:02,922: DEBUG - ++ tail -n1
2025-01-05 20:40:02,929: DEBUG - + default_character_set=utf8mb4
2025-01-05 20:40:02,929: DEBUG - + default_character_set=--default-character-set=utf8mb4
2025-01-05 20:40:02,929: DEBUG - + mysql --default-character-set=utf8mb4 -B nextcloud
2025-01-05 20:40:02,943: INFO - [##++................] > Setting up source files...
2025-01-05 20:40:02,946: DEBUG - + ynh_setup_source --dest_dir=/var/www/nextcloud
2025-01-05 20:40:02,981: DEBUG - + keep=
2025-01-05 20:40:02,983: DEBUG - + full_replace=0
2025-01-05 20:40:02,983: DEBUG - + source_id=main
2025-01-05 20:40:02,983: DEBUG - ++ ynh_read_manifest 'resources.sources["main"]'
2025-01-05 20:40:02,984: DEBUG - ++ cat /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/manifest.toml
2025-01-05 20:40:02,984: DEBUG - ++ toml_to_json
2025-01-05 20:40:02,984: DEBUG - ++ jq '.resources.sources["main"]' --raw-output
2025-01-05 20:40:02,984: DEBUG - ++ python3 -c 'import toml, json, sys; print(json.dumps(toml.load(sys.stdin)))'
2025-01-05 20:40:03,051: DEBUG - + local 'sources_json={
2025-01-05 20:40:03,051: DEBUG - "url": "https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2",
2025-01-05 20:40:03,051: DEBUG - "sha256": "eb6aaba9acef442f2b3e4a996b7ee8a5ed24442f9bba681237fb28ed970e1fa5"
2025-01-05 20:40:03,052: DEBUG - }'
2025-01-05 20:40:03,052: DEBUG - + jq -re .url
2025-01-05 20:40:03,091: DEBUG - https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2
2025-01-05 20:40:03,091: DEBUG - + local arch_prefix=
2025-01-05 20:40:03,133: DEBUG - + local src_url=https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2
2025-01-05 20:40:03,175: DEBUG - + local src_sum=eb6aaba9acef442f2b3e4a996b7ee8a5ed24442f9bba681237fb28ed970e1fa5
2025-01-05 20:40:03,228: DEBUG - + local src_format=
2025-01-05 20:40:03,266: DEBUG - + local src_in_subdir=
2025-01-05 20:40:03,266: DEBUG - + src_in_subdir=true
2025-01-05 20:40:03,303: DEBUG - + local src_extract=
2025-01-05 20:40:03,342: DEBUG - + local src_platform=
2025-01-05 20:40:03,381: DEBUG - + local src_rename=
2025-01-05 20:40:03,381: DEBUG - + [[ -n https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 ]]
2025-01-05 20:40:03,381: DEBUG - + [[ -n eb6aaba9acef442f2b3e4a996b7ee8a5ed24442f9bba681237fb28ed970e1fa5 ]]
2025-01-05 20:40:03,381: DEBUG - + [[ -z '' ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*\.zip$ ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*/zipball/.*$ ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*\.tar\.gz$ ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*\.tgz$ ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*/tar\.gz/.*$ ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*/tarball/.*$ ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*\.tar\.xz$ ]]
2025-01-05 20:40:03,382: DEBUG - + [[ https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 =~ ^.*\.tar\.bz2$ ]]
2025-01-05 20:40:03,382: DEBUG - + src_format=tar.bz2
2025-01-05 20:40:03,383: DEBUG - ++ echo tar.bz2
2025-01-05 20:40:03,383: DEBUG - ++ tr '[:upper:]' '[:lower:]'
2025-01-05 20:40:03,383: DEBUG - + src_format=tar.bz2
2025-01-05 20:40:03,383: DEBUG - + src_extract=true
2025-01-05 20:40:03,383: DEBUG - + [[ true != \t\r\u\e ]]
2025-01-05 20:40:03,384: DEBUG - ++ dirname /var/cache/yunohost/download/nextcloud/main
2025-01-05 20:40:03,385: DEBUG - + mkdir -p /var/cache/yunohost/download/nextcloud
2025-01-05 20:40:03,386: DEBUG - + src_filename=/var/cache/yunohost/download/nextcloud/main
2025-01-05 20:40:03,386: DEBUG - + '[' tar.bz2 = docker ']'
2025-01-05 20:40:03,386: DEBUG - + '[' -n https://download.nextcloud.com/server/releases/nextcloud-30.0.4.tar.bz2 ']'
2025-01-05 20:40:03,386: DEBUG - + '[' -e /var/cache/yunohost/download/nextcloud/main ']'
2025-01-05 20:40:03,387: DEBUG - + sha256sum --check --status
2025-01-05 20:40:04,202: DEBUG - + '[' '!' -e /var/cache/yunohost/download/nextcloud/main ']'
2025-01-05 20:40:04,203: DEBUG - + sha256sum --check --status
2025-01-05 20:40:05,022: DEBUG - + rm -rf /var/cache/yunohost/files_to_keep_during_setup_source/
2025-01-05 20:40:05,756: DEBUG - + '[' -n '' ']'
2025-01-05 20:40:05,756: DEBUG - + mkdir --parents /var/www/nextcloud
2025-01-05 20:40:05,756: DEBUG - + [[ true == \f\a\l\s\e ]]
2025-01-05 20:40:05,756: DEBUG - + [[ tar.bz2 == \d\o\c\k\e\r ]]
2025-01-05 20:40:05,756: DEBUG - + [[ tar.bz2 == \z\i\p ]]
2025-01-05 20:40:05,756: DEBUG - + local strip=
2025-01-05 20:40:05,756: DEBUG - + '[' true '!=' false ']'
2025-01-05 20:40:05,756: DEBUG - + '[' true == true ']'
2025-01-05 20:40:05,756: DEBUG - + local sub_dirs=1
2025-01-05 20:40:05,756: DEBUG - + strip='--strip-components 1'
2025-01-05 20:40:05,756: DEBUG - + [[ tar.bz2 =~ ^tar.gz|tar.bz2|tar.xz|tar$ ]]
2025-01-05 20:40:05,757: DEBUG - + tar --extract --file=/var/cache/yunohost/download/nextcloud/main --directory=/var/www/nextcloud --strip-components 1
2025-01-05 20:41:32,285: DEBUG - + ynh_safe_rm /var/cache/yunohost/download/nextcloud/main
2025-01-05 20:41:32,286: DEBUG - + local target=/var/cache/yunohost/download/nextcloud/main
2025-01-05 20:41:32,661: DEBUG - + '[' -d /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/patches/main ']'
2025-01-05 20:41:32,661: DEBUG - ++ realpath /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/patches/main
2025-01-05 20:41:32,662: DEBUG - + local patches_folder=/var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/patches/main
2025-01-05 20:41:32,663: DEBUG - + pushd /var/www/nextcloud
2025-01-05 20:41:32,663: DEBUG - /var/www/nextcloud /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/scripts
2025-01-05 20:41:32,663: DEBUG - + for patchfile in "$patches_folder/"*.patch
2025-01-05 20:41:32,663: DEBUG - Applying /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/patches/main/00-add-logout_url-conf.patch
2025-01-05 20:41:32,663: DEBUG - + patch --strip=1
2025-01-05 20:41:37,060: DEBUG - patching file core/Controller/LoginController.php
2025-01-05 20:41:56,124: DEBUG - + for patchfile in "$patches_folder/"*.patch
2025-01-05 20:41:56,125: DEBUG - Applying /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/patches/main/01-disable-CSPv3-nonce_and_allow-YNH-fonts.patch
2025-01-05 20:41:56,125: DEBUG - + patch --strip=1
2025-01-05 20:42:00,160: DEBUG - patching file lib/private/Security/CSP/ContentSecurityPolicyNonceManager.php
2025-01-05 20:42:00,160: DEBUG - patching file lib/public/AppFramework/Http/EmptyContentSecurityPolicy.php
2025-01-05 20:42:01,219: DEBUG - + for patchfile in "$patches_folder/"*.patch
2025-01-05 20:42:01,220: DEBUG - Applying /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/patches/main/02-Allow-for-eval-in-JS-scripts-for-YunoHost-tile.patch
2025-01-05 20:42:01,220: DEBUG - + patch --strip=1
2025-01-05 20:42:05,969: DEBUG - patching file lib/public/AppFramework/Http/ContentSecurityPolicy.php
2025-01-05 20:42:05,969: DEBUG - Hunk #1 succeeded at 25 (offset -17 lines).
2025-01-05 20:42:05,969: DEBUG - + popd
2025-01-05 20:42:05,969: DEBUG - /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/scripts
2025-01-05 20:42:05,969: DEBUG - + '[' -n '' ']'
2025-01-05 20:42:05,969: DEBUG - + rm -rf /var/cache/yunohost/files_to_keep_during_setup_source/
2025-01-05 20:42:05,970: DEBUG - + '[' -n /var/www/nextcloud ']'
2025-01-05 20:42:05,970: DEBUG - + '[' /var/www/nextcloud == /var/www/nextcloud ']'
2025-01-05 20:42:05,970: DEBUG - + _ynh_apply_default_permissions /var/www/nextcloud
2025-01-05 20:42:05,970: DEBUG - + local target=/var/www/nextcloud
2025-01-05 20:42:05,971: DEBUG - + ynh_system_user_exists --username=nextcloud
2025-01-05 20:42:05,980: DEBUG - + getent passwd nextcloud
2025-01-05 20:42:05,983: DEBUG - + '[' -f /var/www/nextcloud ']'
2025-01-05 20:42:05,983: DEBUG - + '[' /var/www/nextcloud == /var/www/nextcloud ']'
2025-01-05 20:42:05,984: DEBUG - ++ ynh_read_manifest resources.install_dir.group
2025-01-05 20:42:05,985: DEBUG - ++ sed s/null//g
2025-01-05 20:42:05,985: DEBUG - ++ cat /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/manifest.toml
2025-01-05 20:42:05,985: DEBUG - ++ sed s/__APP__/nextcloud/g
2025-01-05 20:42:05,986: DEBUG - ++ cut -f1 -d:
2025-01-05 20:42:05,988: DEBUG - ++ toml_to_json
2025-01-05 20:42:05,988: DEBUG - ++ jq .resources.install_dir.group --raw-output
2025-01-05 20:42:05,989: DEBUG - ++ python3 -c 'import toml, json, sys; print(json.dumps(toml.load(sys.stdin)))'
2025-01-05 20:42:06,058: DEBUG - + local group=www-data
2025-01-05 20:42:06,058: DEBUG - + [[ -z www-data ]]
2025-01-05 20:42:06,058: DEBUG - + chmod -R u=rwX,g=rX,o=--- /var/www/nextcloud
2025-01-05 20:42:06,201: DEBUG - + chown -R nextcloud:www-data /var/www/nextcloud
2025-01-05 20:42:06,338: DEBUG - + return
2025-01-05 20:42:11,865: INFO - [####++..............] > Configuring PHP-FPM...
2025-01-05 20:42:11,870: DEBUG - + ynh_config_add_phpfpm
2025-01-05 20:42:11,870: DEBUG - + [[ -n 8.3 ]]
2025-01-05 20:42:11,870: DEBUG - + local php_group=nextcloud
2025-01-05 20:42:11,871: DEBUG - + local php_upload_max_filesize=50M
2025-01-05 20:42:11,871: DEBUG - + local php_process_management=ondemand
2025-01-05 20:42:11,871: DEBUG - ++ _default_php_max_children
2025-01-05 20:42:11,871: DEBUG - +++ ynh_get_ram --total
2025-01-05 20:42:11,891: DEBUG - +++ free=0
2025-01-05 20:42:11,891: DEBUG - +++ total=1
2025-01-05 20:42:11,894: DEBUG - ++++ grep 'total memory'
2025-01-05 20:42:11,894: DEBUG - ++++ LC_ALL=C
2025-01-05 20:42:11,894: DEBUG - ++++ vmstat --stats --unit M
2025-01-05 20:42:11,895: DEBUG - ++++ awk '{print $1}'
2025-01-05 20:42:18,962: DEBUG - +++ local total_ram=8048
2025-01-05 20:42:18,965: DEBUG - ++++ LC_ALL=C
2025-01-05 20:42:18,965: DEBUG - ++++ vmstat --stats --unit M
2025-01-05 20:42:18,965: DEBUG - ++++ grep 'total swap'
2025-01-05 20:42:18,965: DEBUG - ++++ awk '{print $1}'
2025-01-05 20:42:18,967: DEBUG - +++ local total_swap=2047
2025-01-05 20:42:18,967: DEBUG - +++ local total_ram_swap=10095
2025-01-05 20:42:18,967: DEBUG - +++ local ram=10095
2025-01-05 20:42:18,967: DEBUG - +++ echo 10095
2025-01-05 20:42:18,968: DEBUG - ++ local total_ram=10095
2025-01-05 20:42:18,969: DEBUG - ++ local php_max_children=252
2025-01-05 20:42:18,969: DEBUG - ++ '[' 252 -le 0 ']'
2025-01-05 20:42:18,969: DEBUG - +++ nproc
2025-01-05 20:42:24,884: DEBUG - ++ '[' 252 -gt 16 ']'
2025-01-05 20:42:24,884: DEBUG - +++ nproc
2025-01-05 20:42:24,886: DEBUG - ++ php_max_children=16
2025-01-05 20:42:24,886: DEBUG - ++ echo 16
2025-01-05 20:42:24,887: DEBUG - + local php_max_children=16
2025-01-05 20:42:24,888: DEBUG - + local php_memory_limit=128M
2025-01-05 20:42:24,888: DEBUG - ++ mktemp
2025-01-05 20:42:24,890: DEBUG - + local phpfpm_template=/tmp/tmp.cIO1tym0z3
2025-01-05 20:42:24,891: DEBUG - + cat
2025-01-05 20:42:24,892: DEBUG - + '[' ondemand = dynamic ']'
2025-01-05 20:42:24,892: DEBUG - + '[' ondemand = ondemand ']'
2025-01-05 20:42:24,892: DEBUG - + cat
2025-01-05 20:42:24,893: DEBUG - + cat
2025-01-05 20:42:24,894: DEBUG - + '[' -e /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/conf/extra_php-fpm.conf ']'
2025-01-05 20:42:24,894: DEBUG - + cat /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/conf/extra_php-fpm.conf
2025-01-05 20:42:24,895: DEBUG - + mkdir --parents /etc/php/8.3/fpm/pool.d
2025-01-05 20:42:24,896: DEBUG - + ynh_config_add --template=/tmp/tmp.cIO1tym0z3 --destination=/etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:24,942: DEBUG - + jinja=0
2025-01-05 20:42:24,943: DEBUG - + '[' -f /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/conf//tmp/tmp.cIO1tym0z3 ']'
2025-01-05 20:42:24,943: DEBUG - + '[' -f /tmp/tmp.cIO1tym0z3 ']'
2025-01-05 20:42:24,943: DEBUG - + template_path=/tmp/tmp.cIO1tym0z3
2025-01-05 20:42:24,943: DEBUG - + ynh_backup_if_checksum_is_different /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:25,023: DEBUG - + touch /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,568: DEBUG - + chmod 640 /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,571: DEBUG - + _ynh_apply_default_permissions /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,571: DEBUG - + local target=/etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,571: DEBUG - + ynh_system_user_exists --username=nextcloud
2025-01-05 20:42:27,581: DEBUG - + getent passwd nextcloud
2025-01-05 20:42:27,582: DEBUG - + '[' -f /etc/php/8.3/fpm/pool.d/nextcloud.conf ']'
2025-01-05 20:42:27,582: DEBUG - + is_in_dir /etc/php/8.3/fpm/pool.d/nextcloud.conf /var/www/nextcloud
2025-01-05 20:42:27,583: DEBUG - + '[' -n /var/www/nextcloud ']'
2025-01-05 20:42:27,583: DEBUG - ++ realpath /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,584: DEBUG - + local child=/etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,585: DEBUG - ++ realpath /var/www/nextcloud
2025-01-05 20:42:27,586: DEBUG - + local parent=/var/www/nextcloud
2025-01-05 20:42:27,586: DEBUG - + [[ /etc/php/8.3/fpm/pool.d/nextcloud.conf =~ ^/var/www/nextcloud ]]
2025-01-05 20:42:27,586: DEBUG - + is_in_dir /etc/php/8.3/fpm/pool.d/nextcloud.conf /home/yunohost.app/nextcloud
2025-01-05 20:42:27,586: DEBUG - + '[' -n /home/yunohost.app/nextcloud ']'
2025-01-05 20:42:27,587: DEBUG - ++ realpath /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,588: DEBUG - + local child=/etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,588: DEBUG - ++ realpath /home/yunohost.app/nextcloud
2025-01-05 20:42:27,590: DEBUG - + local parent=/home/yunohost.app/nextcloud
2025-01-05 20:42:27,590: DEBUG - + [[ /etc/php/8.3/fpm/pool.d/nextcloud.conf =~ ^/home/yunohost.app/nextcloud ]]
2025-01-05 20:42:27,590: DEBUG - + is_in_dir /etc/php/8.3/fpm/pool.d/nextcloud.conf /etc/nextcloud
2025-01-05 20:42:27,590: DEBUG - + '[' -n /etc/nextcloud ']'
2025-01-05 20:42:27,590: DEBUG - ++ realpath /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,591: DEBUG - + local child=/etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,592: DEBUG - ++ realpath /etc/nextcloud
2025-01-05 20:42:27,593: DEBUG - + local parent=/etc/nextcloud
2025-01-05 20:42:27,593: DEBUG - + [[ /etc/php/8.3/fpm/pool.d/nextcloud.conf =~ ^/etc/nextcloud ]]
2025-01-05 20:42:27,593: DEBUG - + '[' /etc/php/8.3/fpm/pool.d/nextcloud.conf == /var/www/nextcloud ']'
2025-01-05 20:42:27,594: DEBUG - + '[' /etc/php/8.3/fpm/pool.d/nextcloud.conf == /home/yunohost.app/nextcloud ']'
2025-01-05 20:42:27,594: DEBUG - + chmod 400 /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,594: DEBUG - + chown root:root /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:27,596: DEBUG - + [[ 0 == 1 ]]
2025-01-05 20:42:27,596: DEBUG - + cp -f /tmp/tmp.cIO1tym0z3 /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:28,490: DEBUG - + _ynh_replace_vars /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:28,490: DEBUG - + local file=/etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:28,491: DEBUG - ++ grep -oP '__[A-Z0-9]+?[A-Z0-9_]*?[A-Z0-9]*?__' /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:42:28,492: DEBUG - ++ sort --unique
2025-01-05 20:42:28,492: DEBUG - ++ sed 's@__\([^.]*\)__@\L\1@g'
2025-01-05 20:42:28,494: DEBUG - + uniques_vars=('app' 'install_dir' 'php_group' 'php_max_children' 'php_memory_limit' 'php_process_management' 'php_upload_max_filesize' 'php_version')
2025-01-05 20:44:03,699: DEBUG - + ynh_store_file_checksum /etc/php/8.3/fpm/pool.d/nextcloud.conf
2025-01-05 20:44:11,285: DEBUG - + php-fpm8.3 --test
2025-01-05 20:44:33,353: DEBUG - + ynh_systemctl --service=php8.3-fpm --action=reload
2025-01-05 20:44:33,439: DEBUG - + service=php8.3-fpm
2025-01-05 20:44:33,439: DEBUG - + action=reload
2025-01-05 20:44:33,440: DEBUG - + wait_until=
2025-01-05 20:44:33,440: DEBUG - + length=20
2025-01-05 20:44:33,440: DEBUG - + log_path=/var/log/php8.3-fpm/php8.3-fpm.log
2025-01-05 20:44:33,440: DEBUG - + timeout=60
2025-01-05 20:44:33,440: DEBUG - + ynh_in_ci_tests
2025-01-05 20:44:33,440: DEBUG - + '[' reload == stop ']'
2025-01-05 20:44:33,440: DEBUG - + '[' reload == reload ']'
2025-01-05 20:44:33,440: DEBUG - + action=reload-or-restart
2025-01-05 20:44:33,441: DEBUG - ++ date --utc --rfc-3339=seconds
2025-01-05 20:44:33,441: DEBUG - ++ cut -d+ -f1
2025-01-05 20:44:33,441: DEBUG - + local 'time_start=2025-01-05 20:44:33 UTC'
2025-01-05 20:44:33,441: DEBUG - + systemctl reload-or-restart php8.3-fpm
2025-01-05 20:44:37,145: INFO - [######++............] > Configuring NGINX web server...
2025-01-05 20:44:37,149: DEBUG - + is_url_handled --domain=cloud.maindomain.tld --path=/.well-known/caldav
2025-01-05 20:44:37,149: DEBUG - + declare -Ar args_array
2025-01-05 20:44:37,188: DEBUG - ++ curl --insecure --silent --output /dev/null --write-out '%{http_code};%{redirect_url}' https://127.0.0.1/.well-known/caldav --header 'Host: cloud.maindomain.tld' --resolve cloud.maindomain.tld:443:127.0.0.1
2025-01-05 20:44:42,682: DEBUG - + local 'curl_output=404;'
2025-01-05 20:44:42,683: DEBUG - + local http_code=404
2025-01-05 20:44:42,683: DEBUG - + local redirection=
2025-01-05 20:44:42,683: DEBUG - + '[' 404 = 404 ']'
2025-01-05 20:44:42,684: DEBUG - + return 1
2025-01-05 20:44:42,684: DEBUG - + is_url_handled --domain=cloud.maindomain.tld --path=/.well-known/carddav
2025-01-05 20:44:42,684: DEBUG - + declare -Ar args_array
2025-01-05 20:44:42,714: DEBUG - ++ curl --insecure --silent --output /dev/null --write-out '%{http_code};%{redirect_url}' https://127.0.0.1/.well-known/carddav --header 'Host: cloud.maindomain.tld' --resolve cloud.maindomain.tld:443:127.0.0.1
2025-01-05 20:44:42,730: DEBUG - + local 'curl_output=404;'
2025-01-05 20:44:42,730: DEBUG - + local http_code=404
2025-01-05 20:44:42,731: DEBUG - + local redirection=
2025-01-05 20:44:42,731: DEBUG - + '[' 404 = 404 ']'
2025-01-05 20:44:42,731: DEBUG - + return 1
2025-01-05 20:44:42,731: DEBUG - + nginx_extra_conf_dir=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.d
2025-01-05 20:44:42,731: DEBUG - + mkdir -p /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.d
2025-01-05 20:44:42,732: DEBUG - + ynh_config_add_nginx
2025-01-05 20:44:42,733: DEBUG - + local finalnginxconf=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,733: DEBUG - + ynh_config_add --template=nginx.conf --destination=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,769: DEBUG - + jinja=0
2025-01-05 20:44:42,770: DEBUG - + '[' -f /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/conf/nginx.conf ']'
2025-01-05 20:44:42,770: DEBUG - + template_path=/var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/conf/nginx.conf
2025-01-05 20:44:42,770: DEBUG - + ynh_backup_if_checksum_is_different /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,833: DEBUG - + touch /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,834: DEBUG - + chmod 640 /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,835: DEBUG - + _ynh_apply_default_permissions /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,835: DEBUG - + local target=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,835: DEBUG - + ynh_system_user_exists --username=nextcloud
2025-01-05 20:44:42,844: DEBUG - + getent passwd nextcloud
2025-01-05 20:44:42,845: DEBUG - + '[' -f /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf ']'
2025-01-05 20:44:42,845: DEBUG - + is_in_dir /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf /var/www/nextcloud
2025-01-05 20:44:42,846: DEBUG - + '[' -n /var/www/nextcloud ']'
2025-01-05 20:44:42,846: DEBUG - ++ realpath /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,847: DEBUG - + local child=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,848: DEBUG - ++ realpath /var/www/nextcloud
2025-01-05 20:44:42,849: DEBUG - + local parent=/var/www/nextcloud
2025-01-05 20:44:42,849: DEBUG - + [[ /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf =~ ^/var/www/nextcloud ]]
2025-01-05 20:44:42,849: DEBUG - + is_in_dir /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf /home/yunohost.app/nextcloud
2025-01-05 20:44:42,849: DEBUG - + '[' -n /home/yunohost.app/nextcloud ']'
2025-01-05 20:44:42,849: DEBUG - ++ realpath /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,850: DEBUG - + local child=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,851: DEBUG - ++ realpath /home/yunohost.app/nextcloud
2025-01-05 20:44:42,852: DEBUG - + local parent=/home/yunohost.app/nextcloud
2025-01-05 20:44:42,852: DEBUG - + [[ /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf =~ ^/home/yunohost.app/nextcloud ]]
2025-01-05 20:44:42,853: DEBUG - + is_in_dir /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf /etc/nextcloud
2025-01-05 20:44:42,853: DEBUG - + '[' -n /etc/nextcloud ']'
2025-01-05 20:44:42,853: DEBUG - ++ realpath /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,854: DEBUG - + local child=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,854: DEBUG - ++ realpath /etc/nextcloud
2025-01-05 20:44:42,856: DEBUG - + local parent=/etc/nextcloud
2025-01-05 20:44:42,856: DEBUG - + [[ /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf =~ ^/etc/nextcloud ]]
2025-01-05 20:44:42,856: DEBUG - + '[' /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf == /var/www/nextcloud ']'
2025-01-05 20:44:42,856: DEBUG - + '[' /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf == /home/yunohost.app/nextcloud ']'
2025-01-05 20:44:42,857: DEBUG - + chmod 400 /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,857: DEBUG - + chown root:root /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:42,858: DEBUG - + [[ 0 == 1 ]]
2025-01-05 20:44:42,858: DEBUG - + cp -f /var/cache/yunohost/app_tmp_work_dirs/app_xvmyjliz/conf/nginx.conf /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:49,252: DEBUG - + _ynh_replace_vars /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:49,252: DEBUG - + local file=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:49,255: DEBUG - ++ grep -oP '__[A-Z0-9]+?[A-Z0-9_]*?[A-Z0-9]*?__' /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:44:49,255: DEBUG - ++ sort --unique
2025-01-05 20:44:49,255: DEBUG - ++ sed 's@__\([^.]*\)__@\L\1@g'
2025-01-05 20:44:49,256: DEBUG - + uniques_vars=('app' 'domain' 'install_dir' 'path' 'php_version')
2025-01-05 20:46:22,285: DEBUG - + ynh_store_file_checksum /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:46:27,418: DEBUG - + '[' / '!=' / ']'
2025-01-05 20:46:27,419: DEBUG - + ynh_replace '--match=^#root_path_only' --replace= --file=/etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:46:27,979: DEBUG - + sed -i '/fastcgi_param\s*REMOTE_USER/d' /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:46:38,272: DEBUG - + ynh_store_file_checksum /etc/nginx/conf.d/cloud.maindomain.tld.d/nextcloud.conf
2025-01-05 20:46:39,163: DEBUG - + ynh_systemctl --service=nginx --action=reload
2025-01-05 20:46:39,234: DEBUG - + service=nginx
2025-01-05 20:46:39,235: DEBUG - + action=reload
2025-01-05 20:46:39,235: DEBUG - + wait_until=
2025-01-05 20:46:39,235: DEBUG - + length=20
2025-01-05 20:46:39,235: DEBUG - + log_path=/var/log/nginx/nginx.log
2025-01-05 20:46:39,235: DEBUG - + timeout=60
2025-01-05 20:46:39,236: DEBUG - + ynh_in_ci_tests
2025-01-05 20:46:39,236: DEBUG - + '[' reload == stop ']'
2025-01-05 20:46:39,236: DEBUG - + '[' reload == reload ']'
2025-01-05 20:46:39,237: DEBUG - + action=reload-or-restart
2025-01-05 20:46:39,237: DEBUG - ++ date --utc --rfc-3339=seconds
2025-01-05 20:46:39,237: DEBUG - ++ cut -d+ -f1
2025-01-05 20:46:39,238: DEBUG - + local 'time_start=2025-01-05 20:46:39 UTC'
2025-01-05 20:46:39,238: DEBUG - + systemctl reload-or-restart nginx
2025-01-05 20:46:39,854: INFO - [########++..........] > Installing nextcloud...
2025-01-05 20:46:39,857: DEBUG - + chown -R nextcloud:www-data /var/www/nextcloud
2025-01-05 20:46:39,985: DEBUG - + chown -R nextcloud: /home/yunohost.app/nextcloud
2025-01-05 20:46:40,419: DEBUG - ++ ynh_string_random --length=6
2025-01-05 20:46:40,438: DEBUG - ++ length=6
2025-01-05 20:46:42,645: DEBUG - ++ filter=A-Za-z0-9
2025-01-05 20:46:42,645: DEBUG - ++ dd if=/dev/urandom bs=1 count=1000
2025-01-05 20:46:42,645: DEBUG - ++ tr --complement --delete A-Za-z0-9
2025-01-05 20:46:42,646: DEBUG - ++ sed --quiet 's/\(.\{6\}\).*/\1/p'
2025-01-05 20:46:42,646: DEBUG - + admin_password=**********
2025-01-05 20:46:42,647: DEBUG - + exec_occ maintenance:install --database mysql --database-name nextcloud --database-user nextcloud --database-pass ********** --admin-user admin --admin-pass ********** --data-dir /home/yunohost.app/nextcloud/data
2025-01-05 20:46:42,647: DEBUG - + cd /var/www/nextcloud
2025-01-05 20:46:42,647: DEBUG - + ynh_exec_as_app php8.3 --define apc.enable_cli=1 occ --no-interaction --no-ansi maintenance:install --database mysql --database-name nextcloud --database-user nextcloud --database-pass ********** --admin-user admin --admin-pass ********** --data-dir /home/yunohost.app/nextcloud/data
2025-01-05 20:46:42,648: DEBUG - + sudo -u nextcloud env PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin php8.3 --define apc.enable_cli=1 occ --no-interaction --no-ansi maintenance:install --database mysql --database-name nextcloud --database-user nextcloud --database-pass ********** --admin-user admin --admin-pass ********** --data-dir /home/yunohost.app/nextcloud/data
2025-01-05 20:48:02,732: DEBUG - Login is invalid because files already exist for this user
2025-01-05 20:48:02,744: DEBUG - + ynh_die 'Unable to install nextcloud'
2025-01-05 20:48:02,792: WARNING - Unable to install nextcloud
2025-01-05 20:48:03,396: ERROR - Impossible d'installer nextcloud : Une erreur est survenue dans le script d'installation de l'application : Unable to install nextcloud
Not applicable
Didn't found the log file
Not applicable
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
