we have a school running a small site using lighttpd.
i added nextcloud on the root server
when i try localhost/nextcloud i get 404.
how can i overcome this to try this cloud which our school needs
running raspbian stretch ,switch to nginx
root of server is /var/www/html
nc install in /var/www/html/nextclod. which gives me to foo.com/nextcloud 404 not found
foot.com/info.php works
In order to help you, please provide some more information about your server. Which distro do you use, which database and PHP version and based on your error messages the Lighttpd/nginx configurations/vhosts are properly the most important ones. Of course please remove all personal/identifying strings.
