Подскажите в чем проблемма, 3 дня бьюсь.
"reqId": "r3izqxY2pV5kzVyAYjoM",
"level": 3,
"time": "2024-12-26T18:27:01+00:00",
"remoteAddr": "178.64.105.162",
"user": "Oleg",
"app": "index",
"method": "GET",
"url": "/index.php/settings/api/apps/media?fileName=https%3A%2F%2Fnextcloud.com%2Fc%2Fuploads%2F2024%2F09%2FNextcloud-Hub-9-1024x576.jpg",
"message": "Exception thrown: OCP\\Files\\NotFoundException",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36",
"version": "30.0.4.1",
"exception": {
"Exception": "OCP\\Files\\NotFoundException",
"Message": "",
"Code": 0,
"Trace": [
"file": "/var/www/nextcloud/lib/private/Files/Node/Folder.php",
"line": 81,
"function": "getFileInfo",
"class": "OC\\Files\\Node\\Node",
"type": "->"
"file": "/var/www/nextcloud/lib/private/Files/SimpleFS/SimpleFolder.php",
"line": 33,
"function": "getDirectoryListing",
"class": "OC\\Files\\Node\\Folder",
"type": "->"
"file": "/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php",
"line": 149,
"class": "OC\\Files\\SimpleFS\\SimpleFolder",
"type": "->"
"file": "/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",
"line": 208,
"function": "getAppDiscoverMedia",
"class": "OCA\\Settings\\Controller\\AppSettingsController",
"type": "->"
"line": 114,
"function": "executeController",
"class": "OC\\AppFramework\\Http\\Dispatcher",
"type": "->"
"file": "/var/www/nextcloud/lib/private/AppFramework/App.php",
"line": 161,
"function": "dispatch",
"type": "->"
"file": "/var/www/nextcloud/lib/private/Route/Router.php",
"line": 302,
"function": "main",
"class": "OC\\AppFramework\\App",
"type": "::"
"file": "/var/www/nextcloud/lib/base.php",
"line": 1003,
"function": "match",
"class": "OC\\Route\\Router",
"type": "->"
"file": "/var/www/nextcloud/index.php",
"line": 24,
"function": "handleRequest",
"class": "OC",
"type": "::"
"File": "/var/www/nextcloud/lib/private/Files/Node/Node.php",
"Line": 90,
"message": "",
"exception": [],
"CustomMessage": "Exception thrown: OCP\\Files\\NotFoundException"
"id": "676da009bf79d"
