Nextcloud version : 29.0.1.
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04.4 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.52
PHP version (eg, 7.4): 8.3.7
Indexing problem after using Sendent app.
- Using Sendent via Outlook
[index] Error: OCA\Sendent\Service\ConnectedUserService::create(): Argument #3 ($licenseId) must be of type int, null given, called in /var/www/html/nextcloud/apps/sendent/lib/Controller/ConnecteduserApiController.php on line 59 in file '/var/www/html/nextcloud/apps/sendent/lib/Service/ConnectedUserService.php' line 84
GET /index.php/apps/sendent/api/1.0/ping
from 192.168.2.72 by jakabp at 2024. máj. 27. 11:26:49
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'cloud.hidrofilt.hu',
0 =>
0 => '127.0.0.1',
'datadirectory' => '/var/www/html/nextcloud/data',
'skeletondirectory' => '',
'version' => '28.0.5.1',
'overwrite.cli.url' => 'http://127.0.0.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => '***',
'default_phone_region' => 'HU',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_domain' => 'hidrofilt.hu',
'mail_smtphost' => '***',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => '***',
'mail_smtppassword' => '***',
'loglevel' => 2,
'theme' => '',
'updater.secret' => 'xxx',
'integrity.check.disabled' => false,
PASTE HERE
PASTE HERE
{"reqId":"F3CS5rHNMO3ZVXTiUZeG","level":3,"time":"2024-05-27T10:31:09+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Files\\BackgroundJob\\ScanFiles (id: 14, arguments: null)","userAgent":"--","version":"29.0.1.1","exception":{"Exception":"TypeError","Message":"smbclient_readdir(): Argument #2 ($dir) must be of type resource, bool given","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php","line":150,"function":"smbclient_readdir"},{"file":"/var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php","line":94,"function":"readdir","class":"Icewind\\SMB\\Native\\NativeState","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php","line":256,"function":"dir","class":"Icewind\\SMB\\Native\\NativeShare","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php","line":651,"function":"getFolderContents","class":"OCA\\Files_External\\Lib\\Storage\\SMB","type":"->"},{"function":"getDirectoryContent","class":"OCA\\Files_External\\Lib\\Storage\\SMB","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php","line":492,"function":"iterator_to_array"},{"file":"/var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php","line":449,"function":"handleChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php","line":355,"function":"scanChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php","line":622,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php","line":634,"function":"OC\\Files\\Cache\\{closure}","class":"OC\\Files\\Cache\\Scanner","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php","line":621,"function":"runBackgroundScanJob","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Utils/Scanner.php","line":186,"function":"backgroundScan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/html/nextcloud/apps/files/lib/BackgroundJob/ScanFiles.php","line":76,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->"},{"file":"/var/www/html/nextcloud/apps/files/lib/BackgroundJob/ScanFiles.php","line":113,"function":"runScanner","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/html/nextcloud/cron.php","line":176,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php","Line":150,"message":"Error while running background job OCA\\Files\\BackgroundJob\\ScanFiles (id: 14, arguments: null)","exception":{},"CustomMessage":"Error while running background job OCA\\Files\\BackgroundJob\\ScanFiles (id: 14, arguments: null)"}}
