Incorrect index name 'card_value_index'
example
longer
example
here
Nextcloud version (eg, 12.0.2): 16.0.6
Operating system and version (eg, Ubuntu 17.04): Centos 7
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.6
PHP version (eg, 7.1): PHP 7.2.20
After running “occ db:add-missing-indices” it returns
Check indices of the share table.
Check indices of the filecache table.
Check indices of the twofactor_providers table.
Check indices of the login_flow_v2 table.
Check indices of the whats_new table.
Check indices of the cards table.
Check indices of the cards_properties table.
Adding cards_prop_abid index to the cards_properties table, this can take some time...
In AbstractMySQLDriver.php line 125:
  An exception occurred while executing 'DROP INDEX idx_811f5cfa8b26c2e9 ON oc_cards_properties':
  SQLSTATE[42000]: Syntax error or access violation: 1280 Incorrect index name 'card_value_index'
In PDOConnection.php line 109:
In PDOConnection.php line 107:
No, it was there in the 16.0.5 version as well, since it didn’t cause much trouble I waited for the next update.
I already tried to truncate the oc_cards and oc_cards_properties tables, this did not help. Any suggestions?
EDIT: In case it might be relevant, I’m trying to run “occ db:add-missing-indices”
because cards_prop_abid seems to be missing.
FIX: Incorrect index name 'card_value_index'
... Incorrect index name 'card_value_index'
Most likely the index already exists for the database, so I wouldn’t classify this as an essential error, as long as all other things are ok. See
It might help to see how a working table should look like (taken from my server):
> describe oc_cards_properties;
| Field         | Type                | Null | Key | Default | Extra          |
| id            | bigint(20) unsigned | NO   | PRI | NULL    | auto_increment |
| addressbookid | bigint(20)          | NO   | MUL | 0       |                |
| cardid        | bigint(20) unsigned | NO   | MUL | 0       |                |
| name          | varchar(64)         | YES  | MUL | NULL    |                |
| value         | varchar(255)        | YES  | MUL | NULL    |                |
| preferred     | int(11)             | NO   |     | 1       |                |
The indexes should look like this:
> show indexes from oc_cards_properties;
| Table               | Non_unique | Key_name             | Seq_in_index | Column_name   | Collation | Cardinality | Sub_part | Packed | Null | Index_type | Comment | Index_comment |
| nc_cards_properties |          0 | PRIMARY              |            1 | id            | A         |        8117 |     NULL | NULL   |      | BTREE      |         |               |
| nc_cards_properties |          1 | card_contactid_index |            1 | cardid        | A         |        2705 |     NULL | NULL   |      | BTREE      |         |               |
| nc_cards_properties |          1 | card_name_index      |            1 | name          | A         |          30 |     NULL | NULL   | YES  | BTREE      |         |               |
| nc_cards_properties |          1 | card_value_index     |            1 | value         | A         |        8117 |     NULL | NULL   | YES  | BTREE      |         |               |
| nc_cards_properties |          1 | cards_prop_abid      |            1 | addressbookid | A         |          16 |     NULL | NULL   |      | BTREE      |         |               |
Thank you for your insight! I’ve been looking into this for weeks. After your example I understood what went wrong, so I tried to drop the index:
MariaDB [******]>  DROP INDEX idx_811f5cfa8b26c2e9 ON oc_cards_properties;
Which gave me this error:
ERROR 1280 (42000): Incorrect index name 'card_value_index'
So I dropped that one as well:
DROP INDEX card_value_index ON oc_cards_properties;
And there it went:
Query OK, 0 rows affected (0.04 sec)
Records: 0  Duplicates: 0  Warnings: 0
With me finally being able to drop the other one:
Query OK, 0 rows affected (0.01 sec)
After which
ran with no trouble at all:
cards_properties table updated successfully.
Thank you so much!
(also thanks for not hand feeding me a solution)
For future reference:
I also initiated a filescan afterwards with
occ files:scan --all
Real glad I figured this out, with the most recent update I had to run:
DROP INDEX calendarobject_value_index ON oc_calendarobjects_props;
because of:
An exception occurred while executing ‘CREATE INDEX calendarobject_calid_index ON oc_calendarobjects_props (calendarid, calendartype)’:
SQLSTATE[42000]: Syntax error or access violation: 1280 Incorrect index name ‘calendarobject_value_index’
