Hello everyone,
After searching in lot of diffrebts topics, I’m asking some help.
For several weeks, we have been experiencing a lot of slowdowns on our Nextcloud.
In particular when creating files, loading pages etc.
I went to the admin page and the cpu load seems to be very high, and does not seem to be going down.
With htop we can see that php-fpm seems to take a lot of ressources.
I also see that cron job doesn’t go well. But when I launch it manually, it works. Maybe it’s just a drawback of php slowdowns.
Here are the server characteristics :
| Nextcloud | Nextcloud 22.2.0 |
| OS: | Linux 4.15.0-38-generic x86_64 |
| CPU: | Intel(R) Xeon(R) CPU E3-1220 V2 @ 3.10GHz (4 cores) |
| Memory: | 15.63 GB |
I have around 50 users at the same time.
Here are my apps
- accessibility: 1.8.0
- activity: 2.15.0
- announcementcenter: 6.0.0
- approval: 1.0.7
- calendar: 2.3.4
- circles: 22.1.1
- cloud_federation_api: 1.5.0
- comments: 1.12.0
- contacts: 4.0.3
- contactsinteraction: 1.3.0
- dashboard: 7.2.0
- dav: 1.19.0
- deck: 1.5.3
- federatedfilesharing: 1.12.0
- federation: 1.12.0
- files: 1.17.0
- files_pdfviewer: 2.3.0
- files_rightclick: 1.1.0
- files_sharing: 1.14.0
- files_trashbin: 1.12.0
- files_versions: 1.15.0
- files_videoplayer: 1.11.0
- firstrunwizard: 2.11.0
- forms: 2.3.0
- guests: 2.0.2
- impersonate: 1.9.0
- integration_whiteboard: 0.0.14
- logreader: 2.7.0
- lookup_server_connector: 1.10.0
- nextcloud_announcements: 1.11.0
- notifications: 2.10.1
- oauth2: 1.10.0
- onlyoffice: 7.1.2
- password_policy: 1.12.0
- photos: 1.4.0
- privacy: 1.6.0
- provisioning_api: 1.12.0
- recommendations: 1.1.0
- serverinfo: 1.12.0
- settings: 1.4.0
- sharebymail: 1.12.0
- spreed: 12.1.2
- support: 1.5.0
- systemtags: 1.12.0
- tasks: 0.14.2
- text: 3.3.0
- theming: 1.13.0
- twofactor_backupcodes: 1.11.0
- updatenotification: 1.12.0
- user_status: 1.2.0
- viewer: 1.6.0
- weather_status: 1.2.0
- workflow_pdf_converter: 1.7.0
- workflowengine: 2.4.0
- admin_audit
- caniupdate
- encryption
- files_external
- survey_client
- user_ldap
It still php7.4 but at the time, i tuned php with rieger advice
Here is the script I runned
sed -i "s/;env\[HOSTNAME\] = /env[HOSTNAME] = /" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/;env\[TMP\] = /env[TMP] = /" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/;env\[TMPDIR\] = /env[TMPDIR] = /" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/;env\[TEMP\] = /env[TEMP] = /" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/;env\[PATH\] = /env[PATH] = /" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/pm.max_children = .*/pm.max_children = 240/" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/pm.start_servers = .*/pm.start_servers = 20/" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/pm.min_spare_servers = .*/pm.min_spare_servers = 10/" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/pm.max_spare_servers = .*/pm.max_spare_servers = 20/" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/;pm.max_requests = 500/pm.max_requests = 500/" /etc/php/7.4/fpm/pool.d/www.conf
sed -i "s/output_buffering =.*/output_buffering = 'Off'/" /etc/php/7.4/cli/php.ini
sed -i "s/max_execution_time =.*/max_execution_time = 1800/" /etc/php/7.4/cli/php.ini
sed -i "s/max_input_time =.*/max_input_time = 3600/" /etc/php/7.4/cli/php.ini
sed -i "s/post_max_size =.*/post_max_size = 10240M/" /etc/php/7.4/cli/php.ini
sed -i "s/;upload_tmp_dir =.*/upload_tmp_dir = \/upload_tmp/" /etc/php/7.4/cli/php.ini
sed -i "s/upload_max_filesize =.*/upload_max_filesize = 10240M/" /etc/php/7.4/cli/php.ini
sed -i "s/max_file_uploads =.*/max_file_uploads = 100/" /etc/php/7.4/cli/php.ini
sed -i "s/;date.timezone.*/date.timezone = Europe\/\Berlin/" /etc/php/7.4/cli/php.ini
sed -i "s/;session.cookie_secure.*/session.cookie_secure = True/" /etc/php/7.4/cli/php.ini
sed -i "s/;session.save_path =.*/session.save_path = \"N;700;\/usr\/local\/tmp\/sessions\"/" /etc/php/7.4/cli/php.ini
sed -i '$aapc.enable_cli = 1' /etc/php/7.4/cli/php.ini
sed -i "s/memory_limit = 128M/memory_limit = 512M/" /etc/php/7.4/fpm/php.ini
sed -i "s/output_buffering =.*/output_buffering = 'Off'/" /etc/php/7.4/fpm/php.ini
sed -i "s/max_execution_time =.*/max_execution_time = 1800/" /etc/php/7.4/fpm/php.ini
sed -i "s/max_input_time =.*/max_input_time = 3600/" /etc/php/7.4/fpm/php.ini
sed -i "s/post_max_size =.*/post_max_size = 10240M/" /etc/php/7.4/fpm/php.ini
sed -i "s/;upload_tmp_dir =.*/upload_tmp_dir = \/upload_tmp/" /etc/php/7.4/fpm/php.ini
sed -i "s/upload_max_filesize =.*/upload_max_filesize = 10240M/" /etc/php/7.4/fpm/php.ini
sed -i "s/max_file_uploads =.*/max_file_uploads = 100/" /etc/php/7.4/fpm/php.ini
sed -i "s/;date.timezone.*/date.timezone = Europe\/\Berlin/" /etc/php/7.4/fpm/php.ini
sed -i "s/;session.cookie_secure.*/session.cookie_secure = True/" /etc/php/7.4/fpm/php.ini
sed -i "s/;opcache.enable=.*/opcache.enable=1/" /etc/php/7.4/fpm/php.ini
sed -i "s/;opcache.enable_cli=.*/opcache.enable_cli=1/" /etc/php/7.4/fpm/php.ini
sed -i "s/;opcache.memory_consumption=.*/opcache.memory_consumption=128/" /etc/php/7.4/fpm/php.ini
sed -i "s/;opcache.interned_strings_buffer=.*/opcache.interned_strings_buffer=8/" /etc/php/7.4/fpm/php.ini
sed -i "s/;opcache.max_accelerated_files=.*/opcache.max_accelerated_files=10000/" /etc/php/7.4/fpm/php.ini
sed -i "s/;opcache.revalidate_freq=.*/opcache.revalidate_freq=1/" /etc/php/7.4/fpm/php.ini
sed -i "s/;opcache.save_comments=.*/opcache.save_comments=1/" /etc/php/7.4/fpm/php.ini
sed -i "s/;session.save_path =.*/session.save_path = \"N;700;\/usr\/local\/tmp\/sessions\"/" /etc/php/7.4/fpm/php.ini
sed -i "s/;emergency_restart_threshold =.*/emergency_restart_threshold = 10/" /etc/php/7.4/fpm/php-fpm.conf
sed -i "s/;emergency_restart_interval =.*/emergency_restart_interval = 1m/" /etc/php/7.4/fpm/php-fpm.conf
sed -i "s/;process_control_timeout =.*/process_control_timeout = 10s/" /etc/php/7.4/fpm/php-fpm.conf
sed -i '$aapc.enabled=1' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.file_update_protection=2' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.optimization=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.shm_size=256M' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.include_once_override=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.shm_segments=1' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.ttl=7200' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.user_ttl=7200' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.gc_ttl=3600' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.num_files_hint=1024' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.enable_cli=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.max_file_size=5M' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.cache_by_default=1' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.use_request_time=1' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.slam_defense=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.mmap_file_mask=/usr/local/tmp/apc.XXXXXX' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.stat_ctime=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.canonicalize=1' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.write_lock=1' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.report_autofilter=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.rfc1867=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.rfc1867_prefix =upload_' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.rfc1867_name=APC_UPLOAD_PROGRESS' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.rfc1867_freq=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.rfc1867_ttl=3600' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.lazy_classes=0' /etc/php/7.4/fpm/php.ini
sed -i '$aapc.lazy_functions=0' /etc/php/7.4/fpm/php.ini
sed -i "s/09,39.*/# &/" /etc/cron.d/php
(crontab -l ; echo "09,39 * * * * /usr/lib/php/sessionclean 2>&1") | crontab -u root -
Do you think my server is not enough performant or I can improve some parameters ??
Thanks for your advices
I need more time to really now but at the moment
