Impossible de se connecter aprĂšs reinstallation
La page n’est pas redirigĂ©e correctement
Voila le message d’erreur que j’ai impossible d’acceder au site, voici les logs nextcloud;
{"reqId":"aMmewZsN5OXZ84Zdk23uNQAAAA4","level":3,"time":"2025-09-16T17:30:41+00:00","remoteAddr":"139.155.139.22","user":"--","app":"core","method":"GET","url":"/","message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'db_obierti_cloud.oc_storages' doesn't exist","userAgent":"Mozilla/5.0 (iPhone; CPU iPhone OS 13_2_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.0.3 Mobile/15E148 Safari/604.1","version":"31.0.8.1","exception":{"Exception":"OC\\DB\\Exceptions\\DbalException","Message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'db_obierti_cloud.oc_storages' doesn't exist","Code":1146,"Trace":[{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":53,"function":"wrap","class":"OC\\DB\\Exceptions\\DbalException","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":289,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/StorageGlobal.php","line":61,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":76,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":55,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Cache.php","line":79,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":306,"function":"__construct","class":"OC\\Files\\Cache\\Cache","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1375,"function":"getCache","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1423,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":178,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":138,"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":114,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":382,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":86,"function":"getRootFolder","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":412,"function":"getImage","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":383,"function":"getCustomFavicon","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/URLGenerator.php","line":209,"function":"replaceImagePath","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/template/functions.php","line":224,"function":"imagePath","class":"OC\\URLGenerator","type":"->"},{"file":"/srv/web/obierti-cloud/core/templates/layout.guest.php","line":30,"function":"image_path"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":161,"args":["/srv/web/obierti-cloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":117,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":148,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/srv/web/obierti-cloud/lib/private/DB/Exceptions/DbalException.php","Line":56,"Previous":{"Exception":"Doctrine\\DBAL\\Exception\\TableNotFoundException","Message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'db_obierti_cloud.oc_storages' doesn't exist","Code":1146,"Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1976,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1918,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1111,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":419,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":289,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/StorageGlobal.php","line":61,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":76,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":55,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Cache.php","line":79,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":306,"function":"__construct","class":"OC\\Files\\Cache\\Cache","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1375,"function":"getCache","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1423,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":178,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":138,"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":114,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":382,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":86,"function":"getRootFolder","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":412,"function":"getImage","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":383,"function":"getCustomFavicon","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/URLGenerator.php","line":209,"function":"replaceImagePath","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/template/functions.php","line":224,"function":"imagePath","class":"OC\\URLGenerator","type":"->"},{"file":"/srv/web/obierti-cloud/core/templates/layout.guest.php","line":30,"function":"image_path"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":161,"args":["/srv/web/obierti-cloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":117,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":148,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":49,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'db_obierti_cloud.oc_storages' doesn't exist","Code":1146,"Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1104,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":419,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":289,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/StorageGlobal.php","line":61,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":76,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":55,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Cache.php","line":79,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":306,"function":"__construct","class":"OC\\Files\\Cache\\Cache","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1375,"function":"getCache","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1423,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":178,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":138,"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":114,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":382,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":86,"function":"getRootFolder","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":412,"function":"getImage","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":383,"function":"getCustomFavicon","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/URLGenerator.php","line":209,"function":"replaceImagePath","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/template/functions.php","line":224,"function":"imagePath","class":"OC\\URLGenerator","type":"->"},{"file":"/srv/web/obierti-cloud/core/templates/layout.guest.php","line":30,"function":"image_path"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":161,"args":["/srv/web/obierti-cloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":117,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":148,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":24,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'db_obierti_cloud.oc_storages' doesn't exist","Code":"42S02","Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1104,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":419,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":289,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/StorageGlobal.php","line":61,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":76,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Storage.php","line":55,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Cache.php","line":79,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":306,"function":"__construct","class":"OC\\Files\\Cache\\Cache","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1375,"function":"getCache","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1423,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":178,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":138,"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":114,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":382,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ImageManager.php","line":86,"function":"getRootFolder","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":412,"function":"getImage","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/srv/web/obierti-cloud/apps/theming/lib/ThemingDefaults.php","line":383,"function":"getCustomFavicon","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/URLGenerator.php","line":209,"function":"replaceImagePath","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/template/functions.php","line":224,"function":"imagePath","class":"OC\\URLGenerator","type":"->"},{"file":"/srv/web/obierti-cloud/core/templates/layout.guest.php","line":30,"function":"image_path"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":161,"args":["/srv/web/obierti-cloud/core/templates/layout.guest.php"],"function":"include"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":117,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":148,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_Template.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}}},"message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'db_obierti_cloud.oc_storages' doesn't exist","exception":{"query":"SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `*PREFIX*storages` WHERE `id` = :dcValue1"},"CustomMessage":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'db_obierti_cloud.oc_storages' doesn't exist"}}
voici mes logs apaches:
[Tue Sep 16 17:13:01.228124 2025] [php:notice] [pid 19331] [client 90.14.222.141:57766] Erreur d\xe2\x80\x99\xc3\xa9v\xc3\xa9nement de replanification de t\xc3\xa2che pour le crochet action_scheduler_run_queue. Code d\xe2\x80\x99erreur\xc2\xa0:\xc2\xa0could_not_set. Message d\xe2\x80\x99erreur\xc2\xa0:\xc2\xa0La liste des \xc3\xa9v\xc3\xa8nements planifi\xc3\xa9s n\xe2\x80\x99a pas pu \xc3\xaatre sauvegard\xc3\xa9e.. Donn\xc3\xa9es\xc2\xa0:\xc2\xa0{"schedule":"every_minute","args":["WP Cron"],"interval":60}
[Tue Sep 16 17:18:51.359349 2025] [mpm_prefork:notice] [pid 17975] AH00171: Graceful restart requested, doing restart
[Tue Sep 16 17:18:53.087521 2025] [http2:warn] [pid 17975] AH10034: The mpm module (prefork.c) is not supported by mod_http2. The mpm determines how things are processed in your server. HTTP/2 has more demands in this regard and the currently selected mpm will just not do. This is an advisory warning. Your server will continue to work, but the HTTP/2 protocol will be inactive.
[Tue Sep 16 17:18:53.108489 2025] [mpm_prefork:notice] [pid 17975] AH00163: Apache/2.4.58 (Ubuntu) mod_fcgid/2.3.9 OpenSSL/3.0.13 configured -- resuming normal operations
[Tue Sep 16 17:18:53.108509 2025] [core:notice] [pid 17975] AH00094: Command line: '/usr/sbin/apache2'
[Tue Sep 16 17:18:53.108512 2025] [mpm_prefork:notice] [pid 17975] AH00171: Graceful restart requested, doing restart
[Tue Sep 16 17:18:53.170314 2025] [http2:warn] [pid 17975] AH10034: The mpm module (prefork.c) is not supported by mod_http2. The mpm determines how things are processed in your server. HTTP/2 has more demands in this regard and the currently selected mpm will just not do. This is an advisory warning. Your server will continue to work, but the HTTP/2 protocol will be inactive.
[Tue Sep 16 17:18:53.186291 2025] [mpm_prefork:notice] [pid 17975] AH00163: Apache/2.4.58 (Ubuntu) mod_fcgid/2.3.9 OpenSSL/3.0.13 configured -- resuming normal operations
[Tue Sep 16 17:18:53.186310 2025] [core:notice] [pid 17975] AH00094: Command line: '/usr/sbin/apache2'
[Tue Sep 16 17:33:02.556171 2025] [php:notice] [pid 19690] [client 90.14.222.141:44870] Erreur d\xe2\x80\x99\xc3\xa9v\xc3\xa9nement de replanification de t\xc3\xa2che pour le crochet action_scheduler_run_queue. Code d\xe2\x80\x99erreur\xc2\xa0:\xc2\xa0could_not_set. Message d\xe2\x80\x99erreur\xc2\xa0:\xc2\xa0La liste des \xc3\xa9v\xc3\xa8nements planifi\xc3\xa9s n\xe2\x80\x99a pas pu \xc3\xaatre sauvegard\xc3\xa9e.. Donn\xc3\xa9es\xc2\xa0:\xc2\xa0{"schedule":"every_minute","args":["WP Cron"],"interval":60}
je vous donne aussi mon virtualhost;
<IfModule mod_ssl.c>
<VirtualHost *:443>
        # The ServerName directive sets the request scheme, hostname and port that
        # the server uses to identify itself. This is used when creating
        # redirection URLs. In the context of virtual hosts, the ServerName
        # specifies what hostname must appear in the request's Host: header to
        # match this virtual host. For the default virtual host (this file) this
        # value is not decisive as it is used as a last resort host regardless.
        # However, you must set it for any further virtual host explicitly.
        ServerName obierti-cloud.com
        ServerAlias *obierti-cloud.com
        ServerAdmin contact@obierti.fr
        DocumentRoot /srv/web/obierti-cloud/
        <Directory /srv/web/obierti-cloud/>
                Options +FollowSymlinks
                AllowOverride All
                Require all granted
                <IfModule mod_dav.c>
                        Dav off
                </IfModule>
                SetEnv HOME /srv/web/obierti-cloud
                SetEnv HTTP_HOME /srv/web/obierti-cloud
        </Directory>
        # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
        # error, crit, alert, emerg.
        # It is also possible to configure the loglevel for particular
        # modules, e.g.
        #LogLevel info ssl:warn
        LogLevel error
        LogLevel warn
        # For most configuration files from conf-available/, which are
        # enabled or disabled at a global level, it is possible to
        # include a line for only one particular virtual host. For example the
        # following line enables the CGI configuration for this host only
        # after it has been globally disabled with "a2disconf".
        include conf-available/serve-cgi-bin.conf
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
RewriteCond %{SERVER_NAME} =obierti-cloud.com [OR]
RewriteCond %{SERVER_NAME} =*cloud-obierti.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
SSLCertificateFile /etc/letsencrypt/live/obierti-cloud.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/obierti-cloud.com/privkey.pem
</VirtualHost>
</IfModule>
je suis sous ubuntu 24.04 avec apache et mysql.
Je reste à votre disposition pour plus d’informations.
Merci d’avance.
Le tableau oc_storages n’existe pas. C’est un tableau assez standard (pas liĂ© Ă  une application spĂ©cifique). Comment tu t’es trouvĂ© dans cette situation? Tu as restaurĂ© une base de donnĂ©es d’une ancienne installation? Une nouvelle installation?
Salut
Il faudrait en dire un peu plus sur la façon dont tu as réinstallé ?
En tout cas comme indiqué par @tflidd tu as un gros soucis de db, soit endommagée soit incomplÚte.
Tu as aussi un soucis dans ta configuration apache avec le module mpm qui est mal installé !
VincĂšn
Bonjour et merci pour vos retours cote npm c est ok mais coté base de données que ca bloque alors je suis passe sur une fraiche installation de nextcloud et je tente de me connecter mais incroyable sur chrome ca fonctionne mais sur firefox le site est bloque malgré avoir supprime les cookies. je ne sais pas comment faire avez vous une idée ?
Bonsoir @SebastienObierti, quel est le problĂšme que vous indique firefox ?
