Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 29.0.5): all-in-one hub 9,7
Operating system and version (eg, Ubuntu 24.04): ubuntu 24.04
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 8.3): replace me
Images can be pasted into a whiteboard, but they will not be saved.
After reopeing, a placeholder is shown instead. Regardless whether the images was just pasted or inserted from a file.
- see above
PASTE HERE
PASTE HERE
{"reqId":"R74BVLSZbDw3EzOjcdnV","level":3,"time":"2024-11-05T14:11:06+00:00","remoteAddr":"","user":"--","app":"richdocuments","method":"","url":"--","message":"Failed to fetch discovery: cURL error 7: Failed to connect to steilo.michaelfliegner.de port 443 after 6 ms: Could not connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://steilo.michaelfliegner.de/hosting/discovery","userAgent":"--","version":"30.0.0.14","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 7: Failed to connect to steilo.michaelfliegner.de port 443 after 6 ms: Could not connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://steilo.michaelfliegner.de/hosting/discovery","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[["GuzzleHttp\\Handler\\CurlHandler"],"*** sensitive parameters replaced ***",["GuzzleHttp\\Handler\\CurlFactory"]]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[["GuzzleHttp\\Handler\\CurlHandler"],"*** sensitive parameters replaced ***",["GuzzleHttp\\Handler\\CurlFactory"]]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":142,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/DnsPinMiddleware.php","line":106,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":66,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":333,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":169,"function":"transfer","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/Client.php","line":205,"function":"request","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","https://steilo.michaelfliegner.de/hosting/discovery",["/var/www/html/resources/config/ca-bundle.crt",5,[true],["Nextcloud Server Crawler","gzip"],true]]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Service/DiscoveryService.php","line":59,"function":"get","class":"OC\\Http\\Client\\Client","type":"->","args":["https://steilo.michaelfliegner.de/hosting/discovery",[5,[true]]]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Service/CachedRequestService.php","line":74,"function":"sendRequest","class":"OCA\\Richdocuments\\Service\\DiscoveryService","type":"->","args":[["OC\\Http\\Client\\Client"]]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Backgroundjobs/ObtainCapabilities.php","line":41,"function":"fetch","class":"OCA\\Richdocuments\\Service\\CachedRequestService","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\Richdocuments\\Backgroundjobs\\ObtainCapabilities","type":"->","args":[null]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":83,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":73,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":210,"message":"Failed to fetch discovery: cURL error 7: Failed to connect to steilo.michaelfliegner.de port 443 after 6 ms: Could not connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://steilo.michaelfliegner.de/hosting/discovery","exception":[],"CustomMessage":"Failed to fetch discovery: cURL error 7: Failed to connect to steilo.michaelfliegner.de port 443 after 6 ms: Could not connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://steilo.michaelfliegner.de/hosting/discovery"},"id":"672a4ec4c7b8f"}
{"reqId":"R74BVLSZbDw3EzOjcdnV","level":3,"time":"2024-11-05T14:11:45+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\DAV\\BackgroundJob\\EventReminderJob (id: 13, arguments: null)","userAgent":"--","version":"30.0.0.14","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing a query: SQLSTATE[42803]: Grouping error: 7 ERROR: column \"cr.id\" must appear in the GROUP BY clause or be used in an aggregate function\nLINE 1: SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"...\n ^","Code":7,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1943,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\PostgreSQL\\ExceptionConverter","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1885,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1106,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],"SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"principaluri\", \"cr\".\"notification_date\", \"cr\".\"event_hash\", \"cr\".\"type\" FROM \"oc_calendar_reminders\" \"cr\" INNER JOIN \"oc_calendarobjects\" \"co\" ON \"cr\".\"object_id\" = \"co\".\"id\" INNER JOIN \"oc_calendars\" \"c\" ON \"cr\".\"calendar_id\" = \"c\".\"id\" WHERE \"cr\".\"notification_date\" <= ? GROUP BY \"cr\".\"event_hash\", \"cr\".\"notification_date\", \"cr\".\"type\"",[1730815905],[2]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":415,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"principaluri\", \"cr\".\"notification_date\", \"cr\".\"event_hash\", \"cr\".\"type\" FROM \"oc_calendar_reminders\" \"cr\" INNER JOIN \"oc_calendarobjects\" \"co\" ON \"cr\".\"object_id\" = \"co\".\"id\" INNER JOIN \"oc_calendars\" \"c\" ON \"cr\".\"calendar_id\" = \"c\".\"id\" WHERE \"cr\".\"notification_date\" <= ? GROUP BY \"cr\".\"event_hash\", \"cr\".\"notification_date\", \"cr\".\"type\"",[1730815905],[2],null]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"principaluri\", \"cr\".\"notification_date\", \"cr\".\"event_hash\", \"cr\".\"type\" FROM \"oc_calendar_reminders\" \"cr\" INNER JOIN \"oc_calendarobjects\" \"co\" ON \"cr\".\"object_id\" = \"co\".\"id\" INNER JOIN \"oc_calendars\" \"c\" ON \"cr\".\"calendar_id\" = \"c\".\"id\" WHERE \"cr\".\"notification_date\" <= :dcValue1 GROUP BY \"cr\".\"event_hash\", \"cr\".\"notification_date\", \"cr\".\"type\"",[1730815905],[2]]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":272,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["SELECT `cr`.*, `co`.`calendardata`, `c`.`displayname`, `c`.`principaluri`, `cr`.`notification_date`, `cr`.`event_hash`, `cr`.`type` FROM `*PREFIX*calendar_reminders` `cr` INNER JOIN `*PREFIX*calendarobjects` `co` ON `cr`.`object_id` = `co`.`id` INNER JOIN `*PREFIX*calendars` `c` ON `cr`.`calendar_id` = `c`.`id` WHERE `cr`.`notification_date` <= :dcValue1 GROUP BY `cr`.`event_hash`, `cr`.`notification_date`, `cr`.`type`",[1730815905],[2]]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":249,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[["OC\\DB\\ConnectionAdapter"]]},{"file":"/var/www/html/apps/dav/lib/CalDAV/Reminder/Backend.php","line":53,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/CalDAV/Reminder/ReminderService.php","line":104,"function":"getRemindersToProcess","class":"OCA\\DAV\\CalDAV\\Reminder\\Backend","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/BackgroundJob/EventReminderJob.php","line":50,"function":"processReminders","class":"OCA\\DAV\\CalDAV\\Reminder\\ReminderService","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\DAV\\BackgroundJob\\EventReminderJob","type":"->","args":[null]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":83,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":73,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/API/PostgreSQL/ExceptionConverter.php","Line":87,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[42803]: Grouping error: 7 ERROR: column \"cr.id\" must appear in the GROUP BY clause or be used in an aggregate function\nLINE 1: SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"...\n ^","Code":7,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[["PDOException",["42803",7,"ERROR: column \"cr.id\" must appear in the GROUP BY clause or be used in an aggregate function\nLINE 1: SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"...\n ^"]]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1099,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":415,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"principaluri\", \"cr\".\"notification_date\", \"cr\".\"event_hash\", \"cr\".\"type\" FROM \"oc_calendar_reminders\" \"cr\" INNER JOIN \"oc_calendarobjects\" \"co\" ON \"cr\".\"object_id\" = \"co\".\"id\" INNER JOIN \"oc_calendars\" \"c\" ON \"cr\".\"calendar_id\" = \"c\".\"id\" WHERE \"cr\".\"notification_date\" <= ? GROUP BY \"cr\".\"event_hash\", \"cr\".\"notification_date\", \"cr\".\"type\"",[1730815905],[2],null]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"principaluri\", \"cr\".\"notification_date\", \"cr\".\"event_hash\", \"cr\".\"type\" FROM \"oc_calendar_reminders\" \"cr\" INNER JOIN \"oc_calendarobjects\" \"co\" ON \"cr\".\"object_id\" = \"co\".\"id\" INNER JOIN \"oc_calendars\" \"c\" ON \"cr\".\"calendar_id\" = \"c\".\"id\" WHERE \"cr\".\"notification_date\" <= :dcValue1 GROUP BY \"cr\".\"event_hash\", \"cr\".\"notification_date\", \"cr\".\"type\"",[1730815905],[2]]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":272,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["SELECT `cr`.*, `co`.`calendardata`, `c`.`displayname`, `c`.`principaluri`, `cr`.`notification_date`, `cr`.`event_hash`, `cr`.`type` FROM `*PREFIX*calendar_reminders` `cr` INNER JOIN `*PREFIX*calendarobjects` `co` ON `cr`.`object_id` = `co`.`id` INNER JOIN `*PREFIX*calendars` `c` ON `cr`.`calendar_id` = `c`.`id` WHERE `cr`.`notification_date` <= :dcValue1 GROUP BY `cr`.`event_hash`, `cr`.`notification_date`, `cr`.`type`",[1730815905],[2]]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":249,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[["OC\\DB\\ConnectionAdapter"]]},{"file":"/var/www/html/apps/dav/lib/CalDAV/Reminder/Backend.php","line":53,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/CalDAV/Reminder/ReminderService.php","line":104,"function":"getRemindersToProcess","class":"OCA\\DAV\\CalDAV\\Reminder\\Backend","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/BackgroundJob/EventReminderJob.php","line":50,"function":"processReminders","class":"OCA\\DAV\\CalDAV\\Reminder\\ReminderService","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\DAV\\BackgroundJob\\EventReminderJob","type":"->","args":[null]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":83,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":73,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42803]: Grouping error: 7 ERROR: column \"cr.id\" must appear in the GROUP BY clause or be used in an aggregate function\nLINE 1: SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"...\n ^","Code":"42803","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->","args":[null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1099,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":415,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"principaluri\", \"cr\".\"notification_date\", \"cr\".\"event_hash\", \"cr\".\"type\" FROM \"oc_calendar_reminders\" \"cr\" INNER JOIN \"oc_calendarobjects\" \"co\" ON \"cr\".\"object_id\" = \"co\".\"id\" INNER JOIN \"oc_calendars\" \"c\" ON \"cr\".\"calendar_id\" = \"c\".\"id\" WHERE \"cr\".\"notification_date\" <= ? GROUP BY \"cr\".\"event_hash\", \"cr\".\"notification_date\", \"cr\".\"type\"",[1730815905],[2],null]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"principaluri\", \"cr\".\"notification_date\", \"cr\".\"event_hash\", \"cr\".\"type\" FROM \"oc_calendar_reminders\" \"cr\" INNER JOIN \"oc_calendarobjects\" \"co\" ON \"cr\".\"object_id\" = \"co\".\"id\" INNER JOIN \"oc_calendars\" \"c\" ON \"cr\".\"calendar_id\" = \"c\".\"id\" WHERE \"cr\".\"notification_date\" <= :dcValue1 GROUP BY \"cr\".\"event_hash\", \"cr\".\"notification_date\", \"cr\".\"type\"",[1730815905],[2]]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":272,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["SELECT `cr`.*, `co`.`calendardata`, `c`.`displayname`, `c`.`principaluri`, `cr`.`notification_date`, `cr`.`event_hash`, `cr`.`type` FROM `*PREFIX*calendar_reminders` `cr` INNER JOIN `*PREFIX*calendarobjects` `co` ON `cr`.`object_id` = `co`.`id` INNER JOIN `*PREFIX*calendars` `c` ON `cr`.`calendar_id` = `c`.`id` WHERE `cr`.`notification_date` <= :dcValue1 GROUP BY `cr`.`event_hash`, `cr`.`notification_date`, `cr`.`type`",[1730815905],[2]]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":249,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[["OC\\DB\\ConnectionAdapter"]]},{"file":"/var/www/html/apps/dav/lib/CalDAV/Reminder/Backend.php","line":53,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/CalDAV/Reminder/ReminderService.php","line":104,"function":"getRemindersToProcess","class":"OCA\\DAV\\CalDAV\\Reminder\\Backend","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/BackgroundJob/EventReminderJob.php","line":50,"function":"processReminders","class":"OCA\\DAV\\CalDAV\\Reminder\\ReminderService","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\DAV\\BackgroundJob\\EventReminderJob","type":"->","args":[null]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":83,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/TimedJob.php","line":73,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}},"message":"Error while running background job OCA\\DAV\\BackgroundJob\\EventReminderJob (id: 13, arguments: null)","exception":[],"CustomMessage":"Error while running background job OCA\\DAV\\BackgroundJob\\EventReminderJob (id: 13, arguments: null)"},"id":"672a4ec4c7ab1"}
