example
longer
example
here
Nextcloud version (eg, 20.0.5): 21.0.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41
PHP version (eg, 7.4): PHP 7.4.3
- upgrade to 21.0.1
- upload a new pdf or image
- try to view or download that file after (file will be corrupt, some info is still there but e.g. images have large missing parts)
- view the same file directly from the storage, not via web-ui (file looks perfectly fine)
https://paste.ubuntu.com/p/4nwqhM6Z86/
'passwordsalt' => '<redacted>',
'secret' => '<redacted>',
0 => 'localhost',
1 => '<redacted>',
2 => '<redacted>',
3 => '<redacted>',
'datadirectory' => '/mnt/ncdata',
'dbtype' => 'pgsql',
'version' => '21.0.1.1',
'overwrite.cli.url' => '<redacted>',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => '<redacted>',
'dbpassword' => '<redacted>',
'instanceid' => '<redacted>',
'upgrade.disable-web' => 'true',
'log_type' => 'file',
'loglevel' => '2',
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'mail_smtpmode' => 'smtp',
'remember_login_cookie_lifetime' => '1800',
'log_rotate_size' => '10485760',
'trashbin_retention_obligation' => 'auto, 180',
'versions_retention_obligation' => 'auto, 365',
'redis' =>
'port' => 0,
'timeout' => 0.5,
'dbindex' => 0,
'password' => '<redacted>',
'logtimezone' => 'Europe/Zurich',
'enable_previews' => true,
'enabledPreviewProviders' =>
11 => 'OC\\Preview\\PNG',
12 => 'OC\\Preview\\JPEG',
13 => 'OC\\Preview\\GIF',
14 => 'OC\\Preview\\BMP',
15 => 'OC\\Preview\\MarkDown',
16 => 'OC\\Preview\\MP3',
17 => 'OC\\Preview\\TXT',
18 => 'OC\\Preview\\Movie',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'jpeg_quality' => '60',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_from_address' => 'noreply',
'mail_domain' => '<redacted>',
'mail_smtphost' => '<redacted>',
'mail_smtpport' => '465',
'mail_smtpname' => '<redacted>',
'mail_smtppassword' => '<redacted>',
'default_phone_region' => 'ch',
upon request
