Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
Nextcloud version (eg, 20.0.5): 24.0.12.1
â 26.0.3.2
Operating system and version (eg, Ubuntu 20.04): Docker Apache Image
Apache or nginx version (eg, Apache 2.4.25): Docker Apache Image
PHP version (eg, 7.4): Docker Apache Image
I updated to 26 using the stable
tag but I got the error Exception: Updates between multiple major versions and downgrades are unsupported.
I then tried to go back to version 24 but Iâm getting the error Can't start Nextcloud because the version of the data (26.0.3.2) is higher than the docker image version (24.0.12.1) and downgrading is not supported. Are you sure you have pulled the newest image version?
Is it possible for me to change the version of my database back to 24? Iâm not sure 26 even updated anything.
Is this the first time youâve seen this error? (Y/N): Y
- Be on version 24
- Try to update to version 26
- Notice update will not be possible
- Notice downgraded doesnât work either
'instanceid' => 'xxxxxx',
'passwordsalt' => 'xxxx',
'secret' => 'xxxxx',
0 => 'xxxxxt',
'trusted_proxies' =>
0 => 'xxxxxx',
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'overwrite.cli.url' => 'https://xxxxx.xxxx',
'check_for_working_wellknown_setup' => false,
'version' => '24.0.12.1',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'nextcloud',
'dbpassword' => 'xxxx',
'mail_from_address' => 'postmaster',
'logtimezone' => 'Etc/UTC',
'logdateformat' => 'Y-m-d H:i:s',
'default_phone_region' => 'US',
'loglevel' => 0,
'maintenance' => true,
'theme' => '',
'app_install_overwrite' =>
0 => 'spreed',
1 => 'twofactor_totp',
