I need to setup the phone region in nextcloud using truenas scale
Upon entering nextcloud under administration settings I get this error
Your installation has no default phone region set. This is required to validate phone numbers in the profile settings without a country code. To allow numbers without a country code, please add “default_phone_region” with the respective ISO 3166-1 code of the region to your config file
How do I get into config file to address this. Thank you
Have you tried to use the search function of this forum?
Thank you That fixed the problem.
