I encountered a problem, I installed through the snapshot package, I installed the nginx agent so I would like to amend the nextcloud 64 port x But I encountered a problem chmod: changing permissions of '/ snap / nextcloud / 2184 / conf / : Read-only file system Have you ever encountered? I need help, thanks.
Hi
The documentation as well as many snap topics on here mention the snap package is read-only. This is why you can’t make your modifications.
Thank you for the answer, I now need to modify the nextcloud port need? Nginx takes 80 ports nextcloud default is also 80 port.
