Hello guys, I have followed all the topics but I have not got a solution yet and I will appreciate your help.
Once I try to add an external 2 tb drive which is mounted in /dev/sda1 /mnt/nextcloud,
I got the red icon with an error:
“smbclient” is not installed. Mounting of “SMB/CIFS”, “SMB/CIFS using OC login” is not possible. Please ask your system administrator to install it.
I have installed nextcloud using docker with raspberrypi 4
I have given permission 777
I have installed
apt-get install smbclient
apt-get install php-smbclient
I assumed that I dont have to configure samba, isn’t it? it is just installed, isn’t it?
if I have to configure, what settings do I need for that fodler?
guys, i really need your help, any logs you suggest, any idea, it is the only missing part to use nextcloud I need to complete
I will appreciate any help
thanks
Jose
My configuration here below
Guys I have installed netxcloud in raspberry pi 4 using docker
This is my procedure:
#sudo apt-get update
#sudo apt-get upgrade
#sudo apt install docker docker-compose
Then, I have connected 2 tb drive and I have mounted in /mnt/nextcloud folder
I gave chmod a+wrx nextcloud al permissions
In that folder I created the docker-composer.yml file . Please, follow below:
version: “3”
services:
nextcloud:
image: nextcloud
container_name: nextcloud
environment:
- PUID=1000
- PGID=1000
- TZ=Europe/Madrid
volumes:
- ./nextcloud/config:/config
- ./nextcloud/data:/data
ports:
- 8082:80
depends_on:
- mariadb
mariadb:
image: linuxserver/mariadb
container_name: mariadb
environment:
- PUID=1000
- PGID=1000
MYSQL_ROOT_PASSWORD=Caja123
- TZ=America/Toronto
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
- MYSQL_PASSWORD=Caja123
volumes:
- ./mariadb/config:/config
ports:
- 3306:3306
restart: unless-stopped
then, Run the command:
sudo docker-compose up -d
And I can open the web and configure mariadb account
I have installed also:
