I get an error. I would like to know if anyone knows how to deal with this
Machine translation is used. If there is any unnatural English, I am sorry.
31.0.4.1
Shared hosting environment
LiteSpeed
N/A
- PHP version (e.g, 8.3):
PHP 8.2
Yes
After initial installation was working fine, but errors appeared later
Manual installation on shared hosting
yes- But there was no error.
I’m encountering errors in my Nextcloud logs related to the “admin” user not being recognized by the backend. These errors occur during background tasks, specifically when running the UpdateSingleMetadata job. The admin user exists and was working before. The server is using Redis for caching, and these errors weren’t present immediately after installation.
I am really sorry, but I can not find it. ,
no app in context
NoUserException
Backends provided no user object
issue while running UpdateSingleMetadata
files
NoUserException
Backends provided no user object for admin
{"reqId":"2y0OpoEPAB07nDiry1ex","level":3,"time":"2025-05-10T12:50:33+00:00","remoteAddr":"2404:7a81:5a80:4700:358f:d4ed:8772:6b1f","user":false,"app":"files","method":"GET","url":"/cron.php","message":"Backends provided no user object for admin","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36","version":"31.0.4.1","exception":{"Exception":"OC\\User\\NoUserException","Message":"Backends provided no user object","Code":0,"Trace":[{"function":"getUserFolder","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/Files/Node/LazyRoot.php","line":38,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/FilesMetadata/Job/UpdateSingleMetadata.php","line":41,"function":"getUserFolder","class":"OC\\Files\\Node\\LazyRoot","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OC\\FilesMetadata\\Job\\UpdateSingleMetadata","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/public/BackgroundJob/QueuedJob.php","line":43,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/public/BackgroundJob/QueuedJob.php","line":29,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/cron.php","line":236,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->"}],"File":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/Files/Node/Root.php","Line":340,"message":"Backends provided no user object for admin","exception":{},"CustomMessage":"Backends provided no user object for admin"}}
{"reqId":"2y0OpoEPAB07nDiry1ex","level":2,"time":"2025-05-10T12:50:33+00:00","remoteAddr":"2404:7a81:5a80:4700:358f:d4ed:8772:6b1f","user":false,"app":"no app in context","method":"GET","url":"/cron.php","message":"issue while running UpdateSingleMetadata","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36","version":"31.0.4.1","exception":{"Exception":"OC\\User\\NoUserException","Message":"Backends provided no user object","Code":0,"Trace":[{"function":"getUserFolder","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/Files/Node/LazyRoot.php","line":38,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/FilesMetadata/Job/UpdateSingleMetadata.php","line":41,"function":"getUserFolder","class":"OC\\Files\\Node\\LazyRoot","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OC\\FilesMetadata\\Job\\UpdateSingleMetadata","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/public/BackgroundJob/QueuedJob.php","line":43,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/public/BackgroundJob/QueuedJob.php","line":29,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->"},{"file":"/home/wasabi/domains/cloud.wasabii.net/public_html/cron.php","line":236,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->"}],"File":"/home/wasabi/domains/cloud.wasabii.net/public_html/lib/private/Files/Node/Root.php","Line":340,"message":"issue while running UpdateSingleMetadata","exception":{},"userId":"admin","fileId":27,"CustomMessage":"issue while running UpdateSingleMetadata"}}
2025-05-10 22:34:50.725701 [INFO] [265800] [T0] [127.0.0.1:35526#APVH_www.domain.net] [ACL] Access to context [/data/] is denied!
2025-05-10 22:34:50.872242 [INFO] [265799] [T0] [127.0.0.1:35556#APVH_www.domain.net] [ACL] Access to context [/data/] is denied!
The /data/ folder has permissions of 777. And WAF is not responding.
[0] => Core
[1] => date
[2] => libxml
[3] => openssl
[4] => pcre
[5] => sqlite3
[6] => zlib
[7] => bz2
[8] => calendar
[9] => ctype
[10] => curl
[11] => hash
[12] => filter
[13] => ftp
[14] => gettext
[15] => json
[16] => iconv
[17] => SPL
[18] => pcntl
[19] => random
[20] => readline
[21] => Reflection
[22] => session
[23] => standard
[24] => mbstring
[25] => shmop
[26] => SimpleXML
[27] => tokenizer
[28] => xml
[29] => litespeed
[30] => apcu
[31] => bcmath
[32] => dom
[33] => fileinfo
[34] => gd
[35] => igbinary
[36] => imagick
[37] => intl
[38] => exif
[39] => memcache
[40] => memcached
[41] => msgpack
[42] => PDO
[43] => mysqlnd
[44] => mysqli
[45] => pdo_mysql
[46] => pdo_sqlite
[47] => Phar
[48] => posix
[49] => psr
[50] => redis
[51] => soap
[52] => sockets
[53] => sodium
[54] => sysvsem
[55] => sysvshm
[56] => xmlreader
[57] => xmlrpc
[58] => xmlwriter
[59] => xsl
[60] => zip
[61] => Zend OPcache
0 => 'XXXnet',
'datadirectory' => '/home/XXX/domains/.XXXnet/public_html/data',
'version' => '31.0.4.1',
'overwrite.cli.url' => 'https://XXX.net',
'dbhost' => 'localhost',
'default_phone_region' => 'JP',
'default_timezone' => 'Asia/Tokyo',
'memcache.local' => '\OC\Memcache\APCu',
'memcache.distributed' => '\OC\Memcache\Redis',
'memcache.locking' => '\OC\Memcache\Redis',
'redis' => array(
'host' => '/home/XXXi/.local/bin/redis.sock',
'port' => 0,
'timeout' => 0.0,
Yours faithfully,
