Https not working on nextcloud
Hey guys,
I am new to nextcloud and I installed it on my webspace under gk-communication.at/cloud. As I installed the ‘Talk’ function, I found out that this domain hasn’t got a certificate yet. So I updated it and know all other pages on that webspace have https - for example gk-communication.at/ckw-art (A project I am working on). But for some reason, when I enter gk-communication.at/cloud, there is no https. When I enter https://gk-communication.at/cloud everything works fine, but I don’t wan’t to typ this every time.
Does somebody have an idea how to fix this? Do I have to change anything in the config?
Thanks for your help! Gabriel
do you have a redirect-to-https button in your webspace console?
what exactly is your “web space”?
btw: your cwk-art isn’t save as well.
grafik
Yes you need to open your config.php in your nextcloud folder on the server. Ad “your domain” into the line after:
‘trusted_domains’ =>
See:
This should work.
Why do you not only use
https://cloud.gk-communication.at
https://cloud.gk-communication.at/index.php/login
You can remove the “index.php” from the url
https://github.com/nextcloud/server/issues/22296
Thanks! That worked.
