I have Nextcloud up and running great except for one small issue. The Android app wonāt connect to my server.
It will connect over http but not https. All other apps Iāve tried (iOS, windows, browser) do just fine.
Basically I am using IIS to listen to https:///nextcloud and reverse proxy that to localhost:8080.
The Android app finds the server and I am able to log in but then I just get a message at the top that says āNo Internet Connectionā. Itās lying though.
Iāve attached a screen shot for you. Itās really weird.
On another note I was able to connect using Sold Explorerās Owncloud connection just fine. It really seems to just be the Nextcloud app.
Thanks,
Matt Keener
