example
longer
example
here
Nextcloud version : 16.04
Operating system and version : Solaris 11.4 SRU13 (yes, I know it is not supported)
Apache or nginx version : Apache 2.4.39
PHP version : 7.1.25
The CPU usage of the httpd daemon rises to to 100% (sometimes) when either syncing (Mac or Android) or when viewing directories with pictures in via the web BUI.
This results in the server hanging. Therefore (as I am using a Solaris zone) I have stopped the zone using more than 50% CPU. This means the app fails at that point and hangs. I can access and restart the service, all will then be fine for days/weeks, or until I deliberately hit it
I appreciate I am not using a supported OS, but I have been running it for a while and these issues only started around the update to NC14.
My gut says it is a PHP issue, but my skillset does not go to that.
- Browse a large directory of pictures
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Run OCA\\Files_Versions\\BackgroundJob\\ExpireVersions job with ID 4","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished OCA\\Files_Versions\\BackgroundJob\\ExpireVersions job with ID 4 in 0 seconds","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Run OCA\\Files_Sharing\\DeleteOrphanedSharesJob job with ID 5","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"DeleteOrphanedSharesJob","method":"","url":"--","message":"0 orphaned share(s) deleted","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished OCA\\Files_Sharing\\DeleteOrphanedSharesJob job with ID 5 in 0 seconds","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Run OCA\\Files_Sharing\\ExpireSharesJob job with ID 6","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished OCA\\Files_Sharing\\ExpireSharesJob job with ID 6 in 0 seconds","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Run OCA\\Files\\BackgroundJob\\ScanFiles job with ID 7","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished OCA\\Files\\BackgroundJob\\ScanFiles job with ID 7 in 0 seconds","userAgent":"--","version":"16.0.4.1"}
{"reqId":"bhnyONvHVanCw3uRQpp6","level":0,"time":"2019-09-28T08:15:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Run OCA\\Files\\BackgroundJob\\DeleteOrphanedItems job with ID 8","userAgent":"--","version":"16.0.4.1"}
<lots more then >
{"reqId":"u0l1FcHCinGPCoWyhDRk","level":3,"time":"2019-09-28T08:30:00+00:00","remoteAddr":"192.168.0.32","user":"--","app":"PHP","method":"GET","url":"\/nextcloud\/status.php","message":"hash_hmac(): Unknown hashing algorithm: sha1 at \/var\/www\/nextcloud\/3rdparty\/phpseclib\/phpseclib\/phpseclib\/Crypt\/Hash.php#372","userAgent":"Mozilla\/5.0 (Macintosh) mirall\/2.2.4 (build 1) (Nextcloud)","version":"16.0.4.1"}
{"reqId":"P9ghQcm8oFSO9fAn2T9n","level":3,"time":"2019-09-28T08:30:00+00:00","remoteAddr":"192.168.0.32","user":"--","app":"PHP","method":"GET","url":"\/nextcloud\/status.php","message":"hash_hmac(): Unknown hashing algorithm: sha1 at \/var\/www\/nextcloud\/3rdparty\/phpseclib\/phpseclib\/phpseclib\/Crypt\/Hash.php#372","userAgent":"Mozilla\/5.0 (Macintosh) mirall\/2.2.4 (build 1) (Nextcloud)","version":"16.0.4.1"}
{"reqId":"ZqFo5mTDIScD2hshSrHt","level":3,"time":"2019-09-28T08:30:00+00:00","remoteAddr":"192.168.0.32","user":"--","app":"PHP","method":"GET","url":"\/nextcloud\/ocs\/v2.php\/apps\/notifications\/api\/v2\/notifications","message":"hash_hmac(): Unknown hashing algorithm: sha1 at \/var\/www\/nextcloud\/3rdparty\/phpseclib\/phpseclib\/phpseclib\/Crypt\/Hash.php#372","userAgent":"Mozilla\/5.0 (Macintosh; Intel Mac OS X 10.14; rv:69.0) Gecko\/20100101 Firefox\/69.0","version":"16.0.4.1"}
{"reqId":"b1954LCuqA3vvGKIOgD1","level":3,"time":"2019-09-28T08:30:00+00:00","remoteAddr":"192.168.0.32","user":"--","app":"PHP","method":"GET","url":"\/nextcloud\/ocs\/v2.php\/apps\/notifications\/api\/v2\/notifications","message":"hash_hmac(): Unknown hashing algorithm: sha1 at \/var\/www\/nextcloud\/3rdparty\/phpseclib\/phpseclib\/phpseclib\/Crypt\/Hash.php#372","userAgent":"Mozilla\/5.0 (Macintosh; Intel Mac OS X 10.14; rv:69.0) Gecko\/20100101 Firefox\/69.0","version":"16.0.4.1"}
'passwordsalt' => 'fZnHTc2koNT5ARED0wfZo6dxvrtaIO',
'secret' => 'rd8jImrCfEVM7frCcIJPafTgzETMAW4p7BtonY9WEKqoapBB',
0 => 'localhost',
1 => 'xx.xx.66',
2 => 'xx.xx.66:643',
3 => 'xxxx:643',
4 => 'xxxx:643',
'datadirectory' => '/nextcloud/server/nextcloud/data',
'overwrite.cli.url' => 'http://localhost',
'version' => '16.0.4.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'oc_admin',
'dbpassword' => 'nqN3yhp2NdYReUFTApjjBwYsnOQfLA',
'logtimezone' => 'UTC',
'instanceid' => 'oc798ms43svp',
'loglevel' => 0,
'mail_from_address' => 'xxxxx',
'mail_smtpmode' => 'sendmail',
'mail_domain' => 'xxxxxxx',
'auth.bruteforce.protection.enabled' => false,
'theme' => '',
Current file is empty, no entries since last rotation yesterday
