Hi folks,
Ive been trying to upgrade to http2 from http1.1 issue im facing is when uploading multiple files the upload starts uploading then stops and fails using http1.1 is fine, Ive added the following to the Server block on my nginx install but problem still remains. im using Haproxy on pfSense.
listen 81 http2 proxy_protocol; # haproxy SSL termination + HTTP/2
listen 82 proxy_protocol; # haproxy SSL termination for HTTP/1.1 and lower
My actual Server block what works with http1.1
server {
listen 80;
listen [::]:80;
server_name cloud.mydomain;
add_header X-Robots-Tag none;
add_header Referrer-Policy no-referrer;
add_header Strict-Transport-Security "max-age=3153600; includeSubDomains" always;
#I found this header is needed on Ubuntu, but not on Arch Linux.
add_header X-Frame-Options "SAMEORIGIN";
root /usr/share/nginx/nextcloud/;
access_log /var/log/nginx/nextcloud.access;
error_log /var/log/nginx/nextcloud.error;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
location ~ /.well-known/acme-challenge {
allow all;
# set max upload size
client_max_body_size 1024M;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
location / {
rewrite ^ /index.php;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34]).php(?:$|/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+.php)(/.*)$;
fastcgi_pass unix:/run/php/php7.4-fpm.sock;
fastcgi_intercept_errors on;
fastcgi_read_timeout 600;
proxy_read_timeout 600;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
Adding the cache control header for js and css files
location ~* \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
access_log off;
location ~* .(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
# Optional: Don’t log access to other assets
access_log off;
Thanks
Jack.
