Nextcloud Hub 4 (26.0.1)
I recently switched from nginx reverse proxy to caddy reverse proxy and I have a problem with http headers. I hava in Security & setup warnings
There are some warnings regarding your setup.
The “Strict-Transport-Security” HTTP header is not set to at least “15552000” seconds. For enhanced security, it is recommended to enable HSTS as described in the security tips
Your web server is not properly set up to resolve “/.well-known/caldav”. Further information can be found in the documentation
Your web server is not properly set up to resolve “/.well-known/carddav”. Further information can be found in the documentation
Please double check the installation guides , and check for any errors or warnings in the log.
Check the security of your Nextcloud over our security scan .
In the caddyfile configuration file, I have the headers set as follows
(headers) {
header /* {
Strict-Transport-Security "max-age=31536000; includeSubDomains; preload"
Permissions-Policy interest-cohort=()
X-Xss-Protection "1; mode=block"
X-Content-Type-Options "nosniff"
X-Frame-Options "DENY"
Content-Security-Policy "upgrade-insecure-requests"
Referrer-Policy "strict-origin-when-cross-origin"
Cache-Control "public, max-age=15, must-revalidate"
Feature-Policy "accelerometer 'none'; ambient-light-sensor 'none'; autoplay 'self'; camera 'none'; encrypted-media 'none'; fullscreen 'self'; geo>
Server "No."
When I check the nextcloud website for securityheaders. everything seems to be OK. I only see a problem in duplication.
Content-Security-Policy This policy contains 'unsafe-inline' which is dangerous in the style-src directive.
X-Content-Type-Options There was a duplicate X-Content-Type-Options header.
X-Frame-Options There was a duplicate X-Frame-Options header.
If I remove the headers section from the caddyfile, nextcloud writes this
Has anyone found a solution to this problem?
