Hi!
I want to enable HTTP/2 for Nextcloud, but it doesn’t seem to work.
Basic info:
Debian 8,
Apache/2.4.29,
What is my problem?
I’d like to enable HTTP/2 for my Nextcloud drive, but when I add it to my VirtualHost file, it still doesn’t load via HTTP/2.
What did I do to enable it?
I run my server on Debian 8, so if I wanted to have HTTP/2 enabled, I had to download Apache from testing repository, because HTTP/2 isn’t in stable repository.
After this I enabled http2 module using a command: “a2enmod http2”. It worked perfectly. All of the configuration files for http2 are in place (/etc/apache2/mods-available).
At the end I added: "Protocols h2 http/1.1" to my VirtualHost file which points to Nextcloud.
This in my VirtualHost file:
What is the problem?
When I access Nextcloud or Ampache (alongside Nextcloud), it still doesn’t load via HTTP/2, I also tested it with this website: “https://tools.keycdn.com/http2-test” and it shows me a negative result.
What is wrong, anyone knows? Can anyone help me with that? I would be extremely glad if someone did.
