So i would say this might be a simple problem, but i have not figured out how to fix it. So im going for perfect nextcloud install, like not having any errors atleast, but that seems to go downhill when i tried to fix the hsts error. It has never really been a problem on previous installs, but now im using caddy and suddenly it got worse. so here is the error
Some headers are not set correctly on your instance - The `Strict-Transport-Security` HTTP header is not set (should be at least `15552000` seconds). For enhanced security, it is recommended to enable HSTS. For more details see the documentation ↗
This is a bit wierd for me becouse doing a simple
curl -I https://example.com
gives me the output
strict-transport-security: max-age=15552000; includeSubDomains
Which should just remove the whole error message, no?
im using nextcloud version 30.0.0 aswell as php: 8.2.23 i previously used NPM Nginx proxy manager
my Caddyfile incudes
example.com {
route {
crowdsec
reverse_proxy 192.168.1.145:8080 {
transport http {
read_buffer 20MB
write_buffer 20MB
encode gzip
tls internal
header {
Strict-Transport-Security "max-age=15768000; includeSubDomains"
log {
format json
output file /var/log/caddy/example.com.log
Note: this is just a snippet. Also the max-age is diffrent in the caddyfile becouse i tested if increasing it would do fix the error which it did not do.
