HPB - WebSocket Connection Failed
    • 31.0.2
    • Ubuntu 24.04
    • apache 2.4.58-1ubuntu8.5
    • 8.3
    • YES - With upgrade from 30 to NC31
    • When I try to enable my HPB
    • Bare Metal
With Upgrade to NC 31 (with NC 30 all worked) I get the error that the WebSocket Connections failed when my HPB is configured
2025-03-21_16-04
When I check the browser console I find following:
  • Talk/Spreed Browser and Linux Talk Client still working
  • Mobil Client IOS - Error Message that I have to update the App
When I remove the HPB url from the configuration all working normal.
With upgrade to NC31 I have this behavior. Nothing changed on my hpb server (2.0.2)
Someone have an idea whats could be wrong?
Could not find any related issues in the log. Also not mit Loglevel 0
Arch Brave and Chromium
192.168.12.100 - - [21/Mar/2025:16:15:56 +0100] "GET /ocs/v2.php/apps/spreed/api/v3/signaling/welcome/0 HTTP/2.0" 200 624 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36"
192.168.12.100 - - [21/Mar/2025:16:15:56 +0100] "GET /ocs/v2.php/apps/spreed/api/v3/signaling/settings?token= HTTP/2.0" 403 154 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36"
        "default_language": "de",
        "default_locale": "de_DE",
        "default_phone_region": "DE",
        "htaccess.RewriteBase": "\/",
        "localstorage.umask": 23,
        "upgrade.disable-web": true,
            "localhost",
        "dbtype": "pgsql",
        "version": "31.0.2.1",
        "overwrite.cli.url": "https:\/\/******",
        "dbport": "",
        "log_type": "file",
        "logfile": "\/app\/logs\/nextcloud.log",
        "loglevel": 3,
        "log.condition": {
            "apps": [
                "admin_audit"
        "mail_smtpmode": "smtp",
        "remember_login_cookie_lifetime": "2592000",
        "session_lifetime": "86400",
        "log_rotate_size": "10485760",
        "trashbin_retention_obligation": "auto, 60",
        "versions_retention_obligation": "auto, 180",
        "activity_expire_days": "120",
        "filelocking.enabled": true,
        "redis": {
            "port": 0,
            "dbindex": 0,
            "timeout": 0.5,
        "mail_smtpsecure": "ssl",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpauth": 1,
        "app_install_overwrite": [
            "files_3d",
            "news",
            "camerarawpreviews",
            "ncdownloader",
            "files_pdfviewer",
            "unsplash",
            "radio",
            "files_trackdownloads",
            "files_downloadactivity"
        "preview_concurrency_new": "4",
        "preview_concurrency_all": "8",
        "enabledPreviewProviders": [
            "OC\\Preview\\Imaginary",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\OpenDocument",
            "OC\\Preview\\Krita",
            "OC\\Preview\\Illustrator",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\Movie",
            "OC\\Preview\\MSOffice2003",
            "OC\\Preview\\MSOffice2007",
            "OC\\Preview\\MSOfficeDoc",
            "OC\\Preview\\PDF",
            "OC\\Preview\\SVG",
            "OC\\Preview\\Font",
            "OC\\Preview\\PNG",
            "OC\\Preview\\ImaginaryPDF"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 80,
        "preview_max_memory": "256",
        "twofactor_enforced": "true",
            "admin"
        "twofactor_enforced_excluded_groups": [
        "memories.exiftool": "\/app\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/app\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "theme": "",
        "maintenance_window_start": 2,
        "files.chunked_upload.max_size": 104857600
Small update.
Requested a test HPB from Struktur AG. Same behavior
The message says „Cannot use talk“, so I assume that you restricted talk to certain groups and you’re not part of any of that group. Check admin->talk settings
@SysKeeper Thanks for your reply.
Was the right hint.
I not expected that the group admin has to be added to the allow group for talk.
Was also not the behavior before (<NC31)
Makes no sense for me, that a configuration which only a user with admin privileges can edit is not allowed to verify it.
Nevertheless the connect working and expect that the failed “test” was only the permission topic.
But still have the problem, that my IOS Client comes up with the message that the app have to be updated (app to old) as soon the HPB configuration is in place.
The Client(s) already on the latest available Version (21.0.0). 21.0.1 not available in the app store till now.
Can you check if Nextcloud Talk ios outdated helps you?
Yes, the new encryption option was the problem. I never activated it but simply to activate and deactivate it, solved the problem.
