I create a nextcloud server v27 with docker-compose.
version: '3.9'
services:
office-nextcloud:
image: nextcloud:27.1.7
container_name: &app_name office-nextcloud
hostname: *app_name
extra_hosts:
- "nextcloud.xxxx.com: ip"
ports:
- 8080:80
volumes:
- ./vol/nextcloud/html:/var/www/html
environment:
- MYSQL_HOST=office-mysql
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=root
- MYSQL_PASSWORD=
depends_on:
- office-mysql
office-mysql:
image: mysql:5.7
container_name: &app_name office-mysql
hostname: *app_name
And manually install Nextcloud Office and Collabora Online - Built-in CODE Server app.
They are all worked well.
And I create a nginx proxy for ssl. Same time disable nextcloud http port.
office-nginx:
image: nginx:1.19.10_230703
container_name: &app_name office-nginx
hostname: *app_name
extra_hosts:
ports:
- 8080:8080
volumes:
- ./vol/nginx/ssl:/ssl
- ./vol/nginx/conf/nginx.conf:/etc/nginx/nginx.conf
- ./vol/nginx/conf/nginx-access.log:/etc/nginx/nginx-access.log
- ./vol/nginx/conf/nginx-error.log:/etc/nginx/nginx-error.log
depends_on:
- office-nextcloud
I also modify the config.php with ‘overwriteprotocol’ => ‘https’.
The nextcloud is worked well. But I can’t open docs any more. The setting always focus on “https://nextcloud.xxxx.com:8080/app/coll*****/proxy?***” ( I can’t remember all about it. But almost it is.)
Here is the nginx config:
worker_processes 1;
events {
worker_connections 1024;
error_log /etc/nginx/nginx-error.log error;
http {
include mime.types;
default_type application/octet-stream;
sendfile on;
keepalive_timeout 65;
access_log /etc/nginx/nginx-access.log combined;
server {
listen 8080 ssl http2;
listen [::]:8080 ssl http2;
server_name nextcloud.xxxx.com;
# ssl on;
ssl_certificate /ssl/1/cert.pem;
ssl_certificate_key /ssl/1/key.pem;
ssl_password_file /ssl/1/cert.pwd;
client_max_body_size 1G;
location / {
proxy_pass http://office-nextcloud;
proxy_set_header Host $http_host;
proxy_redirect off;
Other file can open but not docx odt file.
