How do I update Right Click? I keep getting this notification in Windows 10.
Hi Neolithical,
It looks like it points to the app “Right click” on your NC server. Just login with your admin user or a user with admin permissions and click on your Avatar -> Apps. Here you can see all your installed apps and should have an “Update” button on the right hand side.
Thanks, that was it!
